Zooz zen76 s2 buttons
While trying to create button automations in RM, Basic Rules and Button controller apps, the Held, Double pressed and released actions are not recognized. I had to goto Webcore to get this to work, which it does.
I knew it had to be an apps issue, cause the devices setup page showed these buttons working as expected.
The C7 hub is running the lasted release and all apps were checked for any updates.
Might be an issue with scene control turned on? With that you don't get "double tapped" for instance because the double tap is just a different button #. IIRC up is 1 down is 2 then double up 3 double down 4 and so on up to 5x presses so the zooz switches/dimmers can have 10 buttons when scene control is enabled.
