Hi all
So I have 4 of these LED top lights in the house
2 of em are connected to Leviton DZ6HD dimmers and work great, no issues
the other 2 were on normal analog on/off switches until this past month, when I installed Zooz Zen72's.
I'm running into this weird hysteresis issue, where if I start at 100% brightness, I can go down to 5%. But if I start at 0% and go up, the light doesn't turn on until 17%. So I'm pretty sure that 17% isnt' the minimum brightness for the light because I can get it to 5% if I start at 17% and go down, but can't get to 5% if I start at 0 and go up. This happens both operating using the dimmer paddle as well as zwave/hubitat.
Any ideas? Should I be using a Zen77 instead? I don't think its the light fixture because it works with the Levitons?
Thanks in advance
