Is it possible to add parameter 16 to the "Zooz Central Scene Dimmer" driver?
The dim/brite ramp rate when using the toddle on the switch ramps too quickly for us. Based on the below, I changed parameter 16 using your basic Z-Wave tool. It would be nice if I could change using the driver page.
Thanks,
John
Based on this list found in the ST driver:
Parm Size Description
1 1 Paddle Control
2 1 LED Indicator
3 1 Auto Turn-Off
4 4 Turn-off Timer
5 1 Auto Turn-On
6 4 Turn-on Timer
8 1 Power Restore
9 1 Physical Ramp Rate Control
10 1 Minimum Brightness
11 1 Maximum Brightness
12 1 Double Tap
13 1 Scene Control
14 1 Disable Double Tap
15 1 Disable Paddle
16 1 Physical Dimming Speed
17 1 Zwave Ramp Type
18 1 Default Brightness
