Hey all, new guy here. I've just migrated from ST after a couple years, due to the horrible new interface. I was able to convert over everything I cared about into my C-7, and it has been working great, using all GE/Jasco Z-Wave switches and dimmers.
Came across the Zooz Zen26 on Amazon last week, thought I would give them a try. Installing my first one on my front house lights, seemed to connect pretty straightforward. However, I have discovered that my automation is not working - a simple 'on' at sunset, and 'off' at 11pm. The switch works fine physically, and the status of the switch shows correctly on the Dashboard tile and device page. But I am unable to control the switch digitally. I've looked at the Z-Wave logs, and I see messages going out. But nothing happens.
I've tried excluding and then adding the switch back in, but get the same thing every time. Not quite sure what to try next. I'm using the updated 'Zooz Zen26 Central Scene Switch' driver. Have tried the standard Zen26 driver, get the same thing. Have also tried a Generic Z-Wave Smart Switch driver. It seemed to work momentarily, then the device lost connection and I had to Exlude/discover the switch again.
Z-Wave log looks as follows on a typical digital command (tested my patio lights and front sconces at the same time, both turning on. The patio lights turn on, the front sconces do not):
Patio Lights2020-11-10 11:06:27.436 seqNo: 234, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-101 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Patio Lights2020-11-10 11:06:27.434 seqNo: 232, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-104 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Front Sconces New2020-11-10 11:06:27.323 seqNo: 231, routeChanged: false, transmissionTime: 8ms, repeaters: [08, 09], speed: 40 kbs, rssi: [-103 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Front Sconces New2020-11-10 11:06:27.221 seqNo: 231, routeChanged: false, transmissionTime: 7ms, repeaters: [08, 09], speed: 40 kbs
Only difference I'm seeing is that it looks like the front lights are relayed through two other switches. Interestingly, one of those switches is the same patio lights that work just fine. I'm lost for ideas. Any thoughts? Thanks in advance...
Jerry
