I'm trying to install smart switches in the kitchen area. There is a single-pole switch that controls a bunch of lights. I ordered the ZOOZ zen24 dimmer switch and just realized that it says its a 3-way switch. My question is can I use the zen24 as a single-pole switch? If so, should I leave the traveler screw and connect the rest of the wires or is there something different that I need to do?
It can be used either as a 3 way, or single pole. If you only have a single pole switch, then just tighten the traveller screw (so it doesn't hit something like the side of the box) and leave it unused.
