I first like to say, I am new to Hubitat and fairly new to home automation in general. My previous experience was with Smartthings which was easy, but limited. I'm doing my best to learn as I go.
So I'm at a bit of a road block so I hope someone can point me in the right direction. I have a Zooz Zen21 switch controlling a light. I also have two lamps in the room with Sengled bulbs. Per Zooz, the Zen21 now has screen control but I cannot figure out how to set it up. What I'm trying to accomplish is to tap once to turn on the lights, and tap twice to turn on the lamps. But I cannot figure it out. I have a group set up for the two lamps. And a scene set up to turn the lights on. But how to I tie a double tap from the switch to the scene or light group. Thanks in advance for the help!
Hi Michael, If you go into Rule Machine, create a trigger event and select Button as the Capability. You'll then get a list of Button devices you can select. Your ZEN21 should show up there. When you select it, you'll be able to select a button corresponding to the scene (as described in the switch documentation sheet) and what action you took on the button. It should end up something like this:
Thanks for the reply. I did end up doing things a little different then you outlined above but your reply gave me the link I was missing in setting this up. Thanks.
