Zooz Zen16 Wiring and button issues
I have the Zen16 connected to my Liftmaster garage opener. It works ok but I have to hit the physical garage door button twice to open or close it. It seems to behaving like a switch instead of a momentary button.
I also cannot seem to get the physical light button to operate the light on the opener.
Lastly, I want to expose this opener to my Apple Home Automation on my phone to easily open/close my door with minimal taps. Today it exposes like an on/off switch. If I leave the Apple Home switch "off" the physical button/car remotes no longer work.
I would just put the relay outputs in parallel with the wall switch and don't use any input on the ZEN16. Then setup the ZEN16 to just do a monetary 1 seconds closure when turned on to simulate a button press.
Thank you. What is the point of having the inputs in my use case? I was thinking it would be nice to log when the physical button is pressed.
You would lose that but if you have the contacts on the door then I suppose those events (and others generated by the app) will be in the log anyway. I presume you are using the Zooz Garage Door Opener App?
Is the driver issue involving new ZEN16's and ZWJS fixed at this point?
I wasn't aware of that issue. I use other devices to actuate the contact closure anyway. You just need something with a dry contact closure to go in parallel with the wall switch. I use a ZEN51 but if I were doing it again probably would use zen58 and get the 800 chipset. The new ZEN16 800LR will work (aside from the issue you raise) but it seems overkill if you are just doing one door.
At another home I have a Z-Wave smart plug with an arduino connected to it that simulates a very short pulse from a dry contact relay. I did this because my Chamberlain myQ wall panel loses the time clock if the pulse closure is longer than 250-500msec. So I pulse it quickly with the arduino controlled relay so the wall panel clock doesn't reset but the door opens or closes just fine. It's a bit of a Frankenstein solution but has been rock stable for 10+ years with a few different hubs over that time. If the Zooz products could do a fractional (250-500 msec) contact closure under 1 second then this wouldn't be needed (or just live with 1 second and have the wall panel reset every time, I don't really depend on that clock too much anyway).
