I have looked extensively and have not been able to find a good description for all of the connections on the Zen16. The 3 dry contact relays and the input power terminals are fairly clear to understand. In many pictures there appear to be 6 connections for s1 through s3 which may be switches. What are the switch connections for? Do the switch connections allow an alternative method for activating the relays? I simply want to make sure I understand how the device works prior to purchasing one.
The switch connections are inputs. You can configure them to actuate the relays as well.
Thanks for the response. Your assurance and some of the "how to" articles from Zooz help me to appreciate the full capability of this product. At present my application is to replace a sprinkler timer which has ceased to work properly.
Plus, you can use the built in auto/off to maybe cut down a little on hub involvement.
