The Zooz Zen16 multi-relay has a “Auto Turn-off Timer for Relay X” option in the main driver to turn off any of the relays after a certain time. The minimum is 1 minute.
I am wondering if it would be possible to update the built-in driver to also support shorter time periods (500ms, 750ms and 1s would be awesome).
Because the shortest option is currently 1 minute, I have mine setup with a rule to automatically turn off once it is turned on, but on some rare occasions, the rule doesn’t trigger… I use it to trigger a button to turn on/off solar inverter as needed. It doesn’t seem to damage it when the button remains “pressed”, but doesn’t do what I need it to in those rare instances.
I haven’t found any community drivers for it that could do this - if you are aware of one, please let me know!
