I have several Zooz switches configured with physical control disabled which are used to control smart LED bulb.
When a switch is physically pressed, the LED indicator turns off or on along with the light dimming to 100% or 0% respectively.
When I dim the smart light to 0%, the indicator light remains off at the switch, Has anyone found a workaround for this? If I turn the switch off digitally, this physically breaks the circuit leaving me with uncontrollable smart lights.
