Zooz switches device type numbers
Is there a list of device types for the Zooz switches. I installed several and didn't update the label to reflect device type, so now not sure what is where.
I'm sorry, but I'm not following you. Did you modify the driver after pairing the device? The device type is the driver that is assigned and it's listed on the edit device page. Did you change the driver to one that you shouldn't have and now things aren't working?
If you have automation and can see the logs for something going on at the time the Front Entrance should go on then no.
You will have to go into devices and determine what each one is by observing the lights each is connect to by turning on and off each one. Kinda like determining which circuit breakers control which lights / plugs.
Maybe post their ID and someone can match it? I don't think there is a list floating around anywhere.
There are many Zooz switches, so it will be easier if you post what you have instead of us randomly trying to guess.
I am working on updating firmware. When looking at Data section there is a
deviceType.
I fairly sure device type 45329 is a Zen21.
Not sure about the others
I don't have one of those, but I have a Zen22 and it's ID is 45330. It would be a guess that you do have a Zen21.
I should have added this above. The built in (stock Hubitat) drivers don't seem to work well and/or give errors with the newer firmware. Look for bcopeland's drivers for this and other Zooz switches.
If you google the device type followed by the word Zooz, you go to a page at openhab that shows the correspondence you want.
e.g., search for “45330” zooz
and you get the page for the ZEN24 dimmer:
Others are similar.
Weird that the Zen24 and the Zen22 comes up with the same ID. I just checked my Zen24 and they are the same as I posted above.
It’s possible that the data at openhab is wrong.
Sorry I misunderstood your question.
You can compare the hub device type (which is in decimal)
With the device ID shown in the Z-Wave certification list at Cert list for Zooz
Which is in Hex
John
