Zooz Switch Physical Delay adjustment
Is there any way to make the delay when you click the physical button less on the new Zooz Zen 71 ? It's hurting my WAF.
I'm about to go all in on these switches but am worried about the delay too. I know the Inovelli's can be changed from 700ms to 100ms. However they have no stock of the On/Off Red switch so looking at the Zen71 instead.
Forgot to ask, did you ever come up with a solution?
I don't know if it applies here but I found an annoying delay with the physical response on my ZEN21 switches - until I did a firmware update on them and reset them - they worked instantly again - until I reconfigured them once more. I think the firmware update was incidental, I just saw the effect of a reset - eventually I found that the built-in driver seemed to cause the delay, though I'm not sure what parameter was responsible.
When I changed to the "Zooz ZEN switch Advanced" driver from HPM, I was able to configure them the way I wanted and the delay went away.
