Hello,
I have a few Zooz switches on my C7 (upgraded to 2.2.4.153). Having a problem setting parameter 1 on my Zen23 on/off toggle switch.
This should map to the “manual control enabled” setting, but changing that and saving the parameters does not change any of the state variables.
Logs show where I try to change the setting but the device reports back no change in the variable. Any way to determine if this is a problem in HE or on the Zooz switch?
Logs:
dev:772020-12-02 06:46:30.098 pm debugSwitchBinaryReport(value:0)
dev:772020-12-02 06:46:29.979 pm debugrefresh()...
dev:772020-12-02 06:46:27.819 pm warnThere are 1 pending changes, please click the Save button again.
dev:772020-12-02 06:46:23.579 pm debugPaddle Control(#1) = 0
dev:772020-12-02 06:46:22.653 pm debugChanging Manual Control Enabled(#10) from null to 0
dev:772020-12-02 06:46:22.402 pm warndescription logging is: true
dev:772020-12-02 06:46:22.401 pm warndebug logging is: true
dev:772020-12-02 06:46:22.399 pm infoupdated...
dev:772020-12-02 06:46:18.777 pm warnThere are 1 pending changes, please click the Save button again.
dev:772020-12-02 06:46:14.553 pm debugPaddle Control(#1) = 0
dev:772020-12-02 06:46:13.117 pm debugChanging Manual Control Enabled(#10) from null to 1
dev:772020-12-02 06:46:12.695 pm warndescription logging is: true
