Zooz Smart Chime ZSE33
Anyone else attempted to use the Zooz Smart Chime (http://www.getzooz.com/zooz-zse33-smart-chime.html) with Hubitat? I attempted to port the ST device driver over but can't seem to get the chime to work. It worked once with about a 10 min delay when i sent chime command. Logs aren't showing any errors.
Have you tried using the stock Dome Siren driver? They appear to be the same device externally; I'm not sure if their firmware is significantly (or at all) different.
I did initially and nothing worked but appeared the Zwave signal or lack thereof may have been my culprit. :slight_smile:
