I want to install under cabinet lighting for two cabinets in the kitchen. Both will be about 26 inches long. Power outlet is in the cabinet above the microwave, between the two cabinets I want to put lights under.
Since they're both so short, could I just wire both 26 inch strips to one Zooz RGBW dimmer? Both strips' Rs to the same pin on the dimmer, both Gs to the same pin, etc?
The way I understand it, with LED strips the individual LEDs are (in groups) wired in parallel anyway, so wiring them in parallel directly to the controller wouldn't be any different (as far as power requirements etc) than connecting one strip to the end of the other.
