Last week I installed my first smart switch, a Zooz ZEN76. Lots of back and fourth with Zooz (who is great, BTW), some hiccups... but got it!
Now I'm starting to look towards the other areas of my home, and wondering about relays. I see so much talk about Shelly online... but, regardless... what's the general overview of a Switch vs Relay?
I live in a modern townhome so neutral is everywhere. I have zero dimming switches (though there MAY be a place or two I want to have dimming functionality...) and I have a lot of 3-way switches.
One of the first things that comes to mind with a relay is that I assume "Up" and "Down" aren't always what you'd expect, given the extra logic behind the switch? But then this is always the case with 3-way switches anyway...
Seems they definitely save on space, are cheaper, you get to keep your existing switches...
I guess you lose some of smart features like double taps/holds/lights on some of the smart switches? Based on what I'm reading it sounds like the zooz works with 3way setups, which is good to know.
I'm guessing there could be some confusion resuming from a power outage? Switch says "on" but maybe it was turned off via z-wave? Seems like a minor/non-issue to me.
Anything else to know/consider in choosing a smart switch vs hidden relay?
