Zooz Dimmer 100% Brightness Level Bug?
I'm using the Zooz dimmer with the Zooz Central Scene Dimmer driver. I've noticed that I cannot set the level to 100 in any rule as 99 is the highest it will go and still turn the lights on/up. If I use 100, nothing will happen. The same holds true if I try to manually make 100 in the device page as well.
99 is the highest level supported by zwave devices
Gotcha, thanks!
