I have a few older Zen 23 V2 Z-Wave+ toggle switches and have recently started to have trouble with the drivers.
I stopped using "Zooz Central Scene" drivers because they would not report "physical" vs "digital". Instead I have been using the "Generic Z-Wave Smart Switch" drivers which did report the type properly.
Somewhere around around 5/30 this stopped working. Also I now have to hit the "refresh" button on the device page to get the switch to report.
If I change the driver to "Generic Z-Wave Switch" (and hit configure) it works as expected but does not report the proper switch type ("physical"/"digital").
Note: I also tried "Generic Z-Wave Plus Switch" and "Generic Z-Wave Plus Scene Switch" as well... same behavior as the Smart Switch driver - "refresh" forces the report otherwise nothing, events don't show up etc.
What is going on? Am I missing something? The switch is most definitely Z-Wave Plus and sadly cannot upgrade the firmware on those V2 devices.
Thanks but no - still getting the "refresh" bug and interestingly like the system scene drivers when I digitally toggle off it reports as "physical"... I guess it kinda makes sense since @bcopeland wrote those (but maybe not the system ones dunno).
Uh, now none a bunch of my Zooz switches seem to be reporting physical events only digital ones.. even the V3's & 4's? My enbrighten fan switches are working as expected..
Something is afoot at the Circle K apparently - should I do a soft-reset?
Note: a Zooz bathroom light switch seems to be reporting physical events (System Zooz Central Scene Switch) but my kitchen dimmer is not - using community advanced zooz drivers.
So for my kitchen dimmer I switched to the System Central Scene dimmer.. did the configure/debug thing and physical is now reporting... note: this is a V4 dimmer not the V2 switch I have upstairs.
You can try my advanced driver on the older switches, you will just possibly get the "Pending Changes" message because it cannot sync up all the parameters. Otherwise it should work. I do have a parameter test which is supposed to hide any not working parameters as well to get rid of the pending message but I don't have any old devices to thoroughly test it.
@bcopeland, I will have to go in and see what of your old community drivers don't have other good options and should be revived. I will take you up on that offer to continue them when I get some time to do so.
