the v1.10 on the back I think is the new 700 series which I have no idea why they put that on the back because the release firmware is 32.32 (mine says 1.10 and came with 32.32). Unless you have a very old device? Usually the firmware version is put into the "Data" section at the very bottom of the device page.
Couple of things to note, the built in driver is not compatible with that new 700 series device. A new driver for the 700 series device is coming in the next Hubitat release. Also, when you do set parameters you then need to wake the device up (use paperclip on the pinhole in the case to click the button once).
If you need a driver for the ZSE40-700 in the meantime, I can confirm this one works:
