Zoos ZEN15 range test
I've installed the ZEN 15 and it reports to hub. But outside of adding under Z wire diagnostics, I can't figure out how to access the range test capability that Zoos ad says is in the device.
What steps did you try to follow, and where did you get stuck? Here's what the manual says:
How to test Z-Wave network range for my ZEN15?
You can easily check if the Power Switch is within your
Z-Wave hub’s range:
  • Press and hold the Z-Wave button for 6 to 9 seconds
    until the LED indicator turns violet. The LED indicator
    will then report signal strength.
    • Flashing green = direct communication with the
      primary controller is established and still being
      diagnosed
    • Solid green for 2 seconds = direct communication with
      the primary controller is stable
    • Flashing orange = direct communication with the
      primary controller is intermittent and being diagnosed
    • Solid orange = communication quality is fair
    • Solid red = communication with the primary controller
      has failed
  • Press and release the Z-Wave button to exit testing
    mode.
  • NOTE: This function may only be activated once the
    Power Switch has been included to a Z-Wave network.
That being said, I don't think there's really much use to this kind of thing. You can see the same information, plus more, much more easily (and without performing a colorblindness test) by checking out Settings > Z-Wave Details in Hubitat. And if the device included and functions in place, you know it at least has what matters: range to the hub itself or through a repeater.
This kind of thing is probably there for either hubs that don't really give you much (or any) diagnostic info or maybe jsut because it looks cool in marketing/ads.
Thanks! I missed the range test info on the ZEN15 instruction sheet -- for me, a steep learning curve is a love-hate relationship with the mountains of documentation available.
I tried the flashing light test, but wasn't sure I interpreted the output correctly and some of the text was ambiguous e.g. ". . . and still being diagnosed."
It would be nice to have a field strength meter like the ones I've used for wifi -- I've used them to optimally locate repeaters etc. But, as you point out, if the unit is reporting, it is within range -- now onto creating exportable data files with power use over time . . .
