Yep⦠I REALLY need it too
Thanks for the info
Andy
Thanks for the info
Andy
Remove the // on lines 49 and 52. The log.debug output might give a better clue whatās going on there.
Just to confirm, you have installed all 3 items right? The zone motion manager and child apps, and the simulatedmotionsensor device?
Here is a post I made a while back regarding Hubitat calls regarding the hub object. This may help you modify the ZMM app for Hubitat.
Before you spin to many cycles on getting this older copy to work, we will be releasing Zone Motion Controllers quite soon. It will have Mikeās improvements, and be a new built-in app for Hubitat. Stay tunedā¦
Thanks for the info Bruce
Andy
I mostly use this app to use multiple motion sensors in a single room.
If any one of the sensors is āactiveā then the virtual one is too.
The virtual sensor stays active until ALL physical sensors are inactive, plus a configurable timeout (normally about 10 mins for my use case)
So
I put together a little app that does just that.
Itās no where near as sophisticated as Mikeās app and only does this one thing, but if anyone is interested Iām happy to post the code.
It uses the in-built virtual motion sensor.
Andy
I use them opposite your usage. All sensors active = virtual sensor Active.
One sensor Inactive = virtual sensor inactive.
I swear, Iāll get this app out for you guys, hopefully in the next buildā¦
Mike,
appreciate all your hard work⦠I know it must be difficult to prioritize and keep up.
And now that I have my UK z-wave working brilliantly, Iāll be chasing you for your Fibaro RGBW driver
Damn⦠Itās 3am here⦠this thing can be addictive!
Andy
This is all very āhush hushā
In case you guys missed it!
(I did until today)
Andy
Same here. Didn't even know. Regardless, thanks for the awesome app!
Yup, the false motion zone is broken⦠sorry, Iāll get this fixed.
I having issues with zone motion Manager. I have it set for Motion Aggregation and it been rock solid for a year or so but now it won't work. I have 6 motion sensor in my basement and they control the basement lights, the way it is set up is any motion can turn lights on and no motion after period of time turn off. I can see motion from the sensors but it is not turning the Mzone on or off? or active and inactive? is there a issue with the Zone motion?
No issues with zone motion manager, go through each of your motion sensors and be sure they are infact working correctly...
@mike.maxwell in fact I deleted and created a new zone and it's working. Thanks
