Yeah getting the same here. Just un-paired from ST and re-paired on HE.
Fantastic that you've got this far though!!
Let's hope that someone can help with the last little bit. My groovy knowledge is pretty basic, been learning as I go along.
You've done far better than I could! Hats off
Does this help at all?
https://sharkysoft.com/archive/printf/docs/javadocs/lava/clib/stdio/doc-files/specification.htm
For our locks we use the following to add a user code to a lock:
zwave.userCodeV1.userCodeSet(userIdentifier:codeNumber, userIdStatus:1, userCode:code).format()
where codeNumber is an Integer and
code is a String representation of the pin code, IE pin code 1234 -> "1234"
So assuming that state.lastUnrecognisedCode is the actual pin code, IE 1234, then state.lastUnrecognisedCode.toString() should do it.
Similarly, zwaveEvent(hubitat.zwave.commands.usercodev1.UserCodeReport cmd)
Returns the stored code from the device in cmd.userCode as a string
Hi Mike,
The device stores the code for each registerd key fob in hex 10 hex pairs ie F2 3B 47... etc etc. When you use a key Fob the device compares the code with its list of activated keys, and activates the home away controls. When it is an unknown key fob the devices gives the HE the unknown key fob code as a decimal array. If HE wants to add the unknown key fob then the code is sent back to the device telling it to assign it. This last step is my problem as I can't get the code back into the device as a list of hex values.
ah I see, the ST driver is creating a command from scratch, to do this in Hubitat you will want to return a hex string, not an array of hex bytes...
In other words what you want to create would be "630101<8F9B...whatever...>"
OK,
I have a version that can work but it is a bit manual, I'm sure @mike.maxwell can give me the answer
So, the code to set a new keyfob is:
def cmd = [
0x63, // USER_CODE command class
0x01, // USER_CODE SET command
userNumber,
UserCodeSet.USER_ID_STATUS_OCCUPIED]
cmd += newCode
cmd = cmd.collect { String.format("%02x", it).toUpperCase() }.join('')
requests << cmd
newCode is set by a little handler that convers the array to a hex string.
def convertCode (code) {
debug "Converting code $code"
//code = "256"
def newCode = "0x"
def indexStart = 0
def indexEnd = code.indexOf(',')
for (int i = 0; i < 10; i++){
def byteDec = code[indexStart+1..indexEnd-1] as int
codeByte = Integer.toHexString(byteDec)
if (byteDec < 15) {newCode = "$newCode" + "0"}
newCode = "$newCode" + "$codeByte"
indexStart = indexEnd + 1
indexEnd = code.indexOf(',',indexEnd +1)
So if I write:
def newCode = convertCode (state.lastUnrecognisedCode)
debug "newCode = $newCode"
then the logger says "newCode = 0x8f153e0c720001040000" so all should be find? but no. the command doesn't work
if I hardcode the "newCode" as follows
def newCode = 0x8f153e0c720001040000 // (note, no quotation marks)
then the command works and the keyfob is registered and the Zipato works !!! But I have to edit the driver to hardcode the hex value of each fob that I want to register!
I would like to know how I am supposed to tell hubitat to treat newCode as hex (i've tried as hex or as byte etc but come up with nothing)
I'm sure the answer is a one liner but I don't know what that line is!
I have updated my driver on github
change this to newCode = ""
sorry,
Don't quite follow.
the def is currenty
and "convertCode" is what gets the hex string together
well I don't know where the 0x at the beginning of the newCode string is coming from then, but it shouldn't be there.
You're creating a raw zwave command, this is a string, composed of a sequence of hex byte characters.
0x is not required in this context.
thanks @mike.maxwell for the quick reply
ok, so if I hardCode the string then it works (even with the 0x) so
if I use my handler (below) to create new code (with or without the 0x). it sets newCode to 0x8f153e0c720001040000 but the command doesn't work.
//code = "256"
def newCode = "0x"
def indexStart = 0
I think that my handler is creating an ascii string and not raw hex but I don't know how to convert it. log.debug of "Code = $newCode" when hardcoded give the result 679085061807431020183552 and log.debug of "Code = $newcode" when run through my handler gives the string of 0x8f153e0c720001040000 which tells me that Hubitat needs to know that it is in HEX format: I tried "newCode = newCode as hex" but that would have been too easy!
Thanks again for your help
Just updated the driver, but seeing this again.
dev:43602019-05-22 07:35:38.915 pm errorjava.util.IllegalFormatConversionException: x != org.codehaus.groovy.runtime.GStringImpl on line 546 (associate1)
Any further tips?
Brilliant work BTW
I just tried @mike.maxwell suggestion of def newCode = ""
Prior I got this: dev:43602019-05-22 07:39:40.526 pm debugnewCode = 0x8f373859bc5001040000
Now I get this: dev:43602019-05-22 07:43:57.820 pm debugnewCode = 8f373859bc5001040000
Any use to you?
Hi @Royski
OK it's a bit manual at the moment. Once you get your 8F code you need to edit the driver, and paste it in place of my 8f code. You then need to comment out the call to convertcode and then re assign your fob and it should work.
I think I am missing one line of code to convert my string to a hex string for the box, à bit like the "as int" command
Using this method I have associated my 6 keyfobs. It's not a driver that can be used on public release like this but it does what I need
Hate to restart this topic but I have one of these keypads and would like to use it with HE, has anyone completely got this to work?
I'm using one to arm and disarm safety monitor. Three tags associated without too much issue, and they all can arm or disarm the system.
I read this thread for hours trying to work out how to hard code the tags to the keypad in the driver, but in the end I recall the latest community driver for this device just, well, worked.
The driver by @mhutchy is the one I'm using.
Thanks.
Thx C.J. could you point me to that driver please.
Pretty sure the driver I used is just the one linked in post number 8 in this thread, which is dated 2019 when you open the code.
Thanks.
