Zigbee USB outlet
Any recommendations for a 110/120 usb zigbee outlet? Case use, small neon sign that runs on usb. I know that I could do an outlet with a wallwart but I will have two signs plugged in. and would rather maintain seperate outlet instances.
I found one on Amazon, but it is 240v. There are also wifi ones on Amazon, but Zigbee USB outlets seem more rare.
You can buy a standard outlet that has USB ports
and then add a micro Zigbee USB switch:
Other than that, there do not seem to be many options. It saves the wallworts but adds a protruding switch, so I'm not sure much is gained.
does that wall wart have independent USB's or is all on/off
Looks to be Separate:
--【Separate control function】 Each USB can be individually opened or closed in the app
I had been avoiding Ali Express since the tariffs, but I just got an order yesterday. It arrived in less than two weeks, and they paid the tariffs. It came right to my mailbox without delays.
I've never seen one. It's hard enough finding any in-walls with plain old Zigbee.
Use @kkossev ’s driver and you can increase the power output to 12 on the Zigbee radio. Plus it has the same chip as the C-8 as far as I know. These are rock solid on my C-8 and excellent repeaters.
I use a sonoff ZBMicro USB switch plugged into a standard outlet/cord to control some USB powered led under cabinet lights. Has been reliable so far.
