I finally got a working solution.
The new code works; on/off , level and color (hue,sat) adjustment works.
Which code are you using? Which HE hub are you using? I would like to try to replicate your success.
Just a side note: I received a new Arduino "Nano Matter" microcontroller yesterday. It communicates using Matter over Thread. I was able to use one of the example Nano Matter sketches provided by Arduino and created a working Matter over Thread RGBW Bulb device. I paired it to my Apple Home system using my Apple TV 4K as the Thread Border Router (TBR). I was then able to also pair(share) the device with Home Assistant. However, I have not been successful trying to pair(share) it with Hubitat. I think the issue is that the device shows up as a Matter Bridge + Matter Device. Hubitat's support for Matter Bridges is still a work in progress, IIRC.
Me too.
I haven't tried that yet, as I mainly use other systems for my Matter devices. I'll try to get around to it this weekend though.
I am using C7 hub.
The code is here:
* SPDX-FileCopyrightText: 2021-2024 Espressif Systems (Shanghai) CO LTD
* SPDX-License-Identifier: LicenseRef-Included
* Zigbee HA_on_off_light Example
* This example code is in the Public Domain (or CC0 licensed, at your option.)
* Unless required by applicable law or agreed to in writing, this
* software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
* CONDITIONS OF ANY KIND, either express or implied.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_check.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "ha/esp_zigbee_ha_standard.h"
#include "esp_zb_light.h"
#if !defined ZB_ED_ROLE
#error Define ZB_ED_ROLE in idf.py menuconfig to compile light (End Device) source code.
#endif
uint8_t standardhue=0,sat=0,colorMode=0,enhancedColorMode=0;
uint16_t hue=0;
bool light_state = 0;
uint8_t light_level = 0;
uint16_t light_color_x = 0;
uint16_t light_color_y = 0;
static const char *TAG = "ESP_ZB_ON_OFF_LIGHT";
/********************* Define functions **************************/
static void bdb_start_top_level_commissioning_cb(uint8_t mode_mask)
ESP_ERROR_CHECK(esp_zb_bdb_start_top_level_commissioning(mode_mask));
void esp_zb_app_signal_handler(esp_zb_app_signal_t *signal_struct)
uint32_t *p_sg_p = signal_struct->p_app_signal;
esp_err_t err_status = signal_struct->esp_err_status;
esp_zb_app_signal_type_t sig_type = *p_sg_p;
switch (sig_type) {
case ESP_ZB_ZDO_SIGNAL_SKIP_STARTUP:
ESP_LOGI(TAG, "Zigbee stack initialized");
esp_zb_bdb_start_top_level_commissioning(ESP_ZB_BDB_MODE_INITIALIZATION);
break;
case ESP_ZB_BDB_SIGNAL_DEVICE_FIRST_START:
case ESP_ZB_BDB_SIGNAL_DEVICE_REBOOT:
if (err_status == ESP_OK) {
ESP_LOGI(TAG, "Device started up in %s factory-reset mode", esp_zb_bdb_is_factory_new() ? "" : "non");
if (esp_zb_bdb_is_factory_new()) {
ESP_LOGI(TAG, "Start network steering");
esp_zb_bdb_start_top_level_commissioning(ESP_ZB_BDB_MODE_NETWORK_STEERING);
} else {
ESP_LOGI(TAG, "Device rebooted");
} else {
/* commissioning failed */
ESP_LOGW(TAG, "Failed to initialize Zigbee stack (status: %s)", esp_err_to_name(err_status));
break;
case ESP_ZB_BDB_SIGNAL_STEERING:
esp_zb_ieee_addr_t extended_pan_id;
esp_zb_get_extended_pan_id(extended_pan_id);
ESP_LOGI(TAG, "Joined network successfully (Extended PAN ID: %02x:%02x:%02x:%02x:%02x:%02x:%02x:%02x, PAN ID: 0x%04hx, Channel:%d, Short Address: 0x%04hx)",
extended_pan_id[7], extended_pan_id[6], extended_pan_id[5], extended_pan_id[4],
extended_pan_id[3], extended_pan_id[2], extended_pan_id[1], extended_pan_id[0],
esp_zb_get_pan_id(), esp_zb_get_current_channel(), esp_zb_get_short_address());
} else {
ESP_LOGI(TAG, "Network steering was not successful (status: %s)", esp_err_to_name(err_status));
esp_zb_scheduler_alarm((esp_zb_callback_t)bdb_start_top_level_commissioning_cb, ESP_ZB_BDB_MODE_NETWORK_STEERING, 1000);
break;
default:
ESP_LOGI(TAG, "ZDO signal: %s (0x%x), status: %s", esp_zb_zdo_signal_to_string(sig_type), sig_type,
break;
static esp_err_t zb_attribute_handler(const esp_zb_zcl_set_attr_value_message_t *message)
esp_err_t ret = ESP_OK;
ESP_RETURN_ON_FALSE(message, ESP_FAIL, TAG, "Empty message");
ESP_RETURN_ON_FALSE(message->info.status == ESP_ZB_ZCL_STATUS_SUCCESS, ESP_ERR_INVALID_ARG, TAG, "Received message: error status(%d)",
message->info.status);
ESP_LOGI(TAG, "Received message: endpoint(%d), cluster(0x%x), attribute(0x%x), data size(%d)", message->info.dst_endpoint, message->info.cluster,
message->attribute.id, message->attribute.data.size);
if (message->info.dst_endpoint == HA_ESP_LIGHT_ENDPOINT) {
switch (message->info.cluster) {
case ESP_ZB_ZCL_CLUSTER_ID_ON_OFF:
if (message->attribute.id == ESP_ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID && message->attribute.data.type == ESP_ZB_ZCL_ATTR_TYPE_BOOL) {
light_state = message->attribute.data.value ? *(bool *)message->attribute.data.value : light_state;
ESP_LOGI(TAG, "Light sets to %s", light_state ? "On" : "Off");
light_driver_set_power(light_state);
} else {
ESP_LOGW(TAG, "On/Off cluster data: attribute(0x%x), type(0x%x)", message->attribute.id, message->attribute.data.type);
break;
case ESP_ZB_ZCL_CLUSTER_ID_COLOR_CONTROL:
if(message->attribute.id == ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_HUE_ID && message->attribute.data.type == ESP_ZB_ZCL_ATTR_TYPE_U8) {
standardhue = message->attribute.data.value ? *(uint8_t *)message->attribute.data.value : standardhue;
sat = *(uint8_t *)esp_zb_zcl_get_attribute(message->info.dst_endpoint, message->info.cluster,ESP_ZB_ZCL_CLUSTER_SERVER_ROLE, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_SATURATION_ID)->data_p;
ESP_LOGI(TAG, "Light color hue changes to %d sat %d", standardhue,sat);
colorMode = 0x00;
enhancedColorMode = 0x00;
light_driver_set_color_hue_sat(standardhue , sat);
} else if(message->attribute.id == ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_SATURATION_ID && message->attribute.data.type == ESP_ZB_ZCL_ATTR_TYPE_U8) {
sat = message->attribute.data.value ? *(uint8_t *)message->attribute.data.value : sat;
hue = *(uint8_t *)esp_zb_zcl_get_attribute(message->info.dst_endpoint, message->info.cluster,ESP_ZB_ZCL_CLUSTER_SERVER_ROLE, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_HUE_ID)->data_p;
ESP_LOGI(TAG, "Light color sat changes to %d hue %d", sat,hue);
colorMode = 0x00;
light_driver_set_color_hue_sat(hue , sat);
} else if(message->attribute.id == ESP_ZB_ZCL_ATTR_COLOR_CONTROL_ENHANCED_CURRENT_HUE_ID && message->attribute.data.type == ESP_ZB_ZCL_ATTR_TYPE_U16) {
hue = message->attribute.data.value ? *(uint16_t *)message->attribute.data.value : hue;
ESP_LOGI(TAG, "Light enhanced color full %d upper8 %d lower8 %d sat %d", hue, ((hue >> 0) & 0xFF), ((hue >> 8) & 0xFF), sat);
colorMode = 0x00;
} else if (message->attribute.id == ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_X_ID && message->attribute.data.type == ESP_ZB_ZCL_ATTR_TYPE_U16) {
light_color_x = message->attribute.data.value ? *(uint16_t *)message->attribute.data.value : light_color_x;
light_color_y = *(uint16_t *)esp_zb_zcl_get_attribute(message->info.dst_endpoint, message->info.cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_Y_ID)->data_p;
ESP_LOGI(TAG, "Light color x changes to 0x%x", light_color_x);
enhancedColorMode = 0x01;
colorMode = 0x01;
} else if (message->attribute.id == ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_Y_ID &&
light_color_y = message->attribute.data.value ? *(uint16_t *)message->attribute.data.value : light_color_y;
light_color_x = *(uint16_t *)esp_zb_zcl_get_attribute(message->info.dst_endpoint, message->info.cluster,ESP_ZB_ZCL_CLUSTER_SERVER_ROLE, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_X_ID)->data_p;
ESP_LOGI(TAG, "Light color y changes to 0x%x", light_color_y);
colorMode = 0x01;
else {
ESP_LOGI(TAG, "Color control cluster data: attribute(0x%x), type(0x%x)", message->attribute.id, message->attribute.data.type);
if(enhancedColorMode == 0x03) {
light_driver_set_color_hue_sat(hue, sat);
if(enhancedColorMode == 0x01) {
light_driver_set_color_xy(light_color_x, light_color_y);
if(enhancedColorMode == 0x00) {
light_driver_set_color_hue_sat(standardhue , sat); //overload for uint8_t
break;
case ESP_ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL:
if (message->attribute.id == ESP_ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID && message->attribute.data.type == ESP_ZB_ZCL_ATTR_TYPE_U8) {
light_level = message->attribute.data.value ? *(uint8_t *)message->attribute.data.value : light_level;
light_driver_set_level((uint8_t)light_level);
ESP_LOGI(TAG, "Light level changes to %d", light_level);
} else {
ESP_LOGW(TAG, "Level Control cluster data: attribute(0x%x), type(0x%x)", message->attribute.id, message->attribute.data.type);
break;
default:
ESP_LOGI(TAG, "Message data: cluster(0x%x), attribute(0x%x) ", message->info.cluster, message->attribute.id);
return ret;
static esp_err_t zb_attribute_handler2(const esp_zb_zcl_set_attr_value_message_t *message)
if (message->info.cluster == ESP_ZB_ZCL_CLUSTER_ID_ON_OFF) {
} else {
ESP_LOGI(TAG, "Other attr");
} else {
ESP_LOGI(TAG, "Other command");
if (message->info.cluster == ESP_ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL) {
ESP_LOGI(TAG, "test");
ESP_LOGI(TAG, "level msg attr id: %d",message->attribute.id );
ESP_LOGI(TAG, "level msg attr data value: %d", *(uint8_t *)message->attribute.data.value );
if (message->info.cluster == ESP_ZB_ZCL_CLUSTER_ID_COLOR_CONTROL) {
ESP_LOGI(TAG, "color msg attr id: %d",message->attribute.id );
ESP_LOGI(TAG, "color msg attr data value: %d", *(uint8_t *)message->attribute.data.value );
return ret;
static esp_err_t zb_action_handler(esp_zb_core_action_callback_id_t callback_id, const void *message)
ESP_LOGI(TAG, "ACTION");
switch (callback_id) {
case ESP_ZB_CORE_SET_ATTR_VALUE_CB_ID:
ret = zb_attribute_handler((esp_zb_zcl_set_attr_value_message_t *)message);
break;
default:
ESP_LOGW(TAG, "Receive Zigbee action(0x%x) callback", callback_id);
break;
return ret;
char modelid[] = {13, 'E', 'S', 'P', '3', '2', 'C', '6', '.', 'L', 'i', 'g', 'h', 't'};
char manufname[] = {9, 'E', 's', 'p', 'r', 'e', 's', 's', 'i', 'f'};
static void esp_zb_task(void *pvParameters)
// // Add the color control cluster and necessary attributes
uint16_t color_attr = ESP_ZB_ZCL_COLOR_CONTROL_COLOR_TEMPERATURE_DEF_VALUE;
uint16_t min_temp = ESP_ZB_ZCL_COLOR_CONTROL_COLOR_TEMP_PHYSICAL_MIN_MIREDS_DEFAULT_VALUE;
uint16_t max_temp = ESP_ZB_ZCL_COLOR_CONTROL_COLOR_TEMP_PHYSICAL_MAX_MIREDS_DEFAULT_VALUE;
uint8_t test_attr, test_attr2, color_mode, color_capabilities,color_capabilities2,color_mode2,color_capabilities3;
color_capabilities3= 1 + 2 + 8;
test_attr = 0;
test_attr2 = 3;
color_mode = 0x0002; // ColorTemperatureMireds
color_capabilities = 0x0018; // Color temperature supported
color_capabilities2 = 0x0018; // Color temperature supported
color_mode2 = 0x0000; // ColorTemperatureMireds
uint16_t zero = 0;
uint8_t colorX = ESP_ZB_ZCL_COLOR_CONTROL_CURRENT_X_DEF_VALUE;
uint8_t colorY = ESP_ZB_ZCL_COLOR_CONTROL_CURRENT_Y_DEF_VALUE;
uint8_t colorMode = 0x0000; // init with hue/sat color mode
uint8_t colorOpts = 0x0001; // not sure what coloropts mean, but i found example with this being 0x1
uint8_t colorECM = 0x0003; // init with standard hue/sat ecm
//uint8_t colorCapabilites = 0x000B; //XY, Hue and Enhanced Hue
uint8_t colorHue = 0x0050;
uint8_t colorSaturation = 0x0000;
uint16_t enhancedHue = 0x0000;
// initialize Zigbee stack with Zigbee end-device config
esp_zb_cfg_t zb_nwk_cfg = ESP_ZB_ZED_CONFIG();
//esp_zb_set_trace_level_mask(ESP_ZB_TRACE_LEVEL_INFO, ESP_ZB_TRACE_SUBSYSTEM_APS);
esp_zb_init(&zb_nwk_cfg);
esp_zb_set_primary_network_channel_set(ESP_ZB_PRIMARY_CHANNEL_MASK);
// set the on-off light device config
//uint8_t test_attr, test_attr2;
//test_attr = 0;
//test_attr2 = 4;
// basic cluster create with fully customized
esp_zb_attribute_list_t *esp_zb_basic_cluster = esp_zb_zcl_attr_list_create(ESP_ZB_ZCL_CLUSTER_ID_BASIC);
esp_zb_basic_cluster_add_attr(esp_zb_basic_cluster, ESP_ZB_ZCL_ATTR_BASIC_ZCL_VERSION_ID, &test_attr);
esp_zb_basic_cluster_add_attr(esp_zb_basic_cluster, ESP_ZB_ZCL_ATTR_BASIC_POWER_SOURCE_ID, &test_attr2);
esp_zb_cluster_update_attr(esp_zb_basic_cluster, ESP_ZB_ZCL_ATTR_BASIC_ZCL_VERSION_ID, &test_attr2);
esp_zb_basic_cluster_add_attr(esp_zb_basic_cluster, ESP_ZB_ZCL_ATTR_BASIC_MODEL_IDENTIFIER_ID, &modelid[0]);
esp_zb_basic_cluster_add_attr(esp_zb_basic_cluster, ESP_ZB_ZCL_ATTR_BASIC_MANUFACTURER_NAME_ID, &manufname[0]);
// identify cluster create with fully customized
esp_zb_attribute_list_t *esp_zb_identify_cluster = esp_zb_zcl_attr_list_create(ESP_ZB_ZCL_CLUSTER_ID_IDENTIFY);
esp_zb_identify_cluster_add_attr(esp_zb_identify_cluster, ESP_ZB_ZCL_ATTR_IDENTIFY_IDENTIFY_TIME_ID, &test_attr);
// group cluster create with fully customized
esp_zb_attribute_list_t *esp_zb_groups_cluster = esp_zb_zcl_attr_list_create(ESP_ZB_ZCL_CLUSTER_ID_GROUPS);
esp_zb_groups_cluster_add_attr(esp_zb_groups_cluster, ESP_ZB_ZCL_ATTR_GROUPS_NAME_SUPPORT_ID, &test_attr);
// scenes cluster create with standard cluster + customized
esp_zb_attribute_list_t *esp_zb_scenes_cluster = esp_zb_scenes_cluster_create(NULL);
esp_zb_cluster_update_attr(esp_zb_scenes_cluster, ESP_ZB_ZCL_ATTR_SCENES_NAME_SUPPORT_ID, &test_attr);
// on-off cluster create with standard cluster config
esp_zb_on_off_cluster_cfg_t on_off_cfg;
on_off_cfg.on_off = ESP_ZB_ZCL_ON_OFF_ON_OFF_DEFAULT_VALUE;
esp_zb_attribute_list_t *esp_zb_on_off_cluster = esp_zb_on_off_cluster_create(&on_off_cfg);
/* level control cluster, fully customized */
esp_zb_attribute_list_t *esp_zb_level_cluster = esp_zb_zcl_attr_list_create(ESP_ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL);
esp_zb_level_cluster_add_attr(esp_zb_level_cluster, ESP_ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID, &test_attr);
/* color control cluster create, fully customized */
esp_zb_attribute_list_t *esp_zb_color_cluster = esp_zb_zcl_attr_list_create(ESP_ZB_ZCL_CLUSTER_ID_COLOR_CONTROL);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_X_ID, ESP_ZB_ZCL_COLOR_CONTROL_CURRENT_X_DEF_VALUE);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_Y_ID, ESP_ZB_ZCL_COLOR_CONTROL_CURRENT_Y_DEF_VALUE);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_MODE_ID, ESP_ZB_ZCL_COLOR_CONTROL_COLOR_MODE_DEFAULT_VALUE);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_OPTIONS_ID, ESP_ZB_ZCL_COLOR_CONTROL_OPTIONS_DEFAULT_VALUE);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_CAPABILITIES_ID, &color_capabilities2);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_MODE_ID, &color_mode2);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_ENHANCED_COLOR_MODE_ID, &color_mode2);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_CAPABILITIES_ID, &color_capabilities);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_TEMPERATURE_ID, &color_attr);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_TEMP_PHYSICAL_MIN_MIREDS_ID, &min_temp);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_TEMP_PHYSICAL_MAX_MIREDS_ID, &max_temp);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_HUE_ID, &colorHue);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_SATURATION_ID, &colorSaturation);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_ENHANCED_CURRENT_HUE_ID, &enhancedHue);
/* YENI YONTEM - fail yapiyor
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_X_ID, &zero);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_Y_ID, &zero);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_MODE_ID, &colorMode);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_OPTIONS_ID, &colorOpts);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_ENHANCED_COLOR_MODE_ID, &colorECM);
esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_COLOR_CAPABILITIES_ID, &colorCapabilites);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_X_ID, &zero);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_Y_ID, &zero);
//esp_zb_color_control_cluster_add_attr(esp_zb_color_cluster, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_OPTIONS_ID, &zero);
// create cluster lists for this endpoint
esp_zb_cluster_list_t *esp_zb_cluster_list = esp_zb_zcl_cluster_list_create();
esp_zb_cluster_list_add_basic_cluster(esp_zb_cluster_list, esp_zb_basic_cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
// update basic cluster in the existed cluster list
//esp_zb_cluster_list_update_basic_cluster(esp_zb_cluster_list, esp_zb_basic_cluster_create(NULL), ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
esp_zb_cluster_list_add_identify_cluster(esp_zb_cluster_list, esp_zb_identify_cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
esp_zb_cluster_list_add_groups_cluster(esp_zb_cluster_list, esp_zb_groups_cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
esp_zb_cluster_list_add_scenes_cluster(esp_zb_cluster_list, esp_zb_scenes_cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
esp_zb_cluster_list_add_on_off_cluster(esp_zb_cluster_list, esp_zb_on_off_cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
esp_zb_cluster_list_add_level_cluster(esp_zb_cluster_list, esp_zb_level_cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
//SONSON
//esp_zb_cluster_list_add_color_control_cluster(esp_zb_cluster_list, esp_zb_color_cluster, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
esp_zb_color_dimmable_light_cfg_t light_cfg = ESP_ZB_DEFAULT_COLOR_DIMMABLE_LIGHT_CONFIG();
light_cfg.color_cfg.color_capabilities += 3;
light_cfg.color_cfg.current_y = 21000;
light_cfg.color_cfg.options = 1;
esp_zb_attribute_list_t *attr_list = esp_zb_color_control_cluster_create(&(light_cfg.color_cfg));
uint8_t sat = 0x22;
uint8_t hue = 0x00;
uint16_t en_hue = 0x0000;
esp_zb_color_control_cluster_add_attr(attr_list, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_HUE_ID, &(hue));
esp_zb_color_control_cluster_add_attr(attr_list, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_CURRENT_SATURATION_ID, &(sat));
esp_zb_color_control_cluster_add_attr(attr_list, ESP_ZB_ZCL_ATTR_COLOR_CONTROL_ENHANCED_CURRENT_HUE_ID, &(en_hue));
esp_zb_cluster_list_add_color_control_cluster(esp_zb_cluster_list, attr_list, ESP_ZB_ZCL_CLUSTER_SERVER_ROLE);
// OTHER METHOD TO CREATE EP
//esp_zb_color_dimmable_light_cfg_t light_cfg = ESP_ZB_DEFAULT_COLOR_DIMMABLE_LIGHT_CONFIG();
//esp_zb_ep_list_t *esp_zb_color_dimmable_light_ep = esp_zb_color_dimmable_light_ep_create(HA_ESP_LIGHT_ENDPOINT, &light_cfg);
//esp_zb_device_register(esp_zb_color_dimmable_light_ep);
esp_zb_ep_list_t *esp_zb_ep_list = esp_zb_ep_list_create();
// add created endpoint (cluster_list) to endpoint list
esp_zb_ep_list_add_ep(esp_zb_ep_list, esp_zb_cluster_list, HA_ESP_LIGHT_ENDPOINT, ESP_ZB_AF_HA_PROFILE_ID, ESP_ZB_HA_COLOR_DIMMABLE_LIGHT_DEVICE_ID);
esp_zb_device_register(esp_zb_ep_list);
esp_zb_core_action_handler_register(zb_action_handler);
//esp_zb_raw_command_handler_register(zb_action_handler_raw);
ESP_ERROR_CHECK(esp_zb_start(false));
esp_zb_main_loop_iteration();
esp_zb_on_off_light_cfg_t light_cfg = ESP_ZB_DEFAULT_ON_OFF_LIGHT_CONFIG();
esp_zb_ep_list_t *esp_zb_on_off_light_ep = esp_zb_on_off_light_ep_create(HA_ESP_LIGHT_ENDPOINT, &light_cfg);
esp_zb_device_register(esp_zb_on_off_light_ep);
void app_main(void)
esp_zb_platform_config_t config = {
.radio_config = ESP_ZB_DEFAULT_RADIO_CONFIG(),
.host_config = ESP_ZB_DEFAULT_HOST_CONFIG(),
ESP_ERROR_CHECK(nvs_flash_init());
ESP_ERROR_CHECK(esp_zb_platform_config(&config));
light_driver_init(LIGHT_DEFAULT_OFF);
xTaskCreate(esp_zb_task, "Zigbee_main", 4096, NULL, 5, NULL);
Blockquote
please don't forget this thread is about zigbee solution.
If you want to discuss about matter , please open another thread.
I tried your code. But I am getting error about light_driver_set_color_hue_sat.
Can you please share your light_driver.c file as well.
sure. here it is:
* SPDX-FileCopyrightText: 2021-2023 Espressif Systems (Shanghai) CO LTD
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form, except as embedded into a Espressif Systems
* integrated circuit in a product or a software update for such product,
* must reproduce the above copyright notice, this list of conditions and
* the following disclaimer in the documentation and/or other materials
* provided with the distribution.
* 3. Neither the name of the copyright holder nor the names of its contributors
* may be used to endorse or promote products derived from this software without
* specific prior written permission.
* 4. Any software provided in binary form under this license must not be reverse
* engineered, decompiled, modified and/or disassembled.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
#include "led_strip.h"
#include "light_driver.h"
static led_strip_handle_t s_led_strip;
static uint8_t s_red = 255, s_green = 255, s_blue = 255, s_level = 255;;
void light_driver_set_color_xy(uint16_t color_current_x, uint16_t color_current_y)
float red_f = 0, green_f = 0, blue_f = 0, color_x, color_y;
color_x = (float)color_current_x / 65535;
color_y = (float)color_current_y / 65535;
/* assume color_Y is full light level value 1 (0-1.0) */
float color_X = color_x / color_y;
float color_Z = (1 - color_x - color_y) / color_y;
/* change from xy to linear RGB NOT sRGB */
XYZ_to_RGB(color_X, 1, color_Z, red_f, green_f, blue_f);
float ratio = (float)s_level / 255;
s_red = (uint8_t)(red_f * (float)255);
s_green = (uint8_t)(green_f * (float)255);
s_blue = (uint8_t)(blue_f * (float)255);
ESP_ERROR_CHECK(led_strip_set_pixel(s_led_strip, 0, s_red * ratio, s_green * ratio, s_blue * ratio));
ESP_ERROR_CHECK(led_strip_refresh(s_led_strip));
void light_driver_set_color_hue_sat(uint8_t hue, uint8_t sat)
float red_f, green_f, blue_f;
HSV_to_RGB(hue, sat, UINT8_MAX, red_f, green_f, blue_f);
s_red = (uint8_t)red_f;
s_green = (uint8_t)green_f;
s_blue = (uint8_t)blue_f;
void light_driver_set_color_RGB(uint8_t red, uint8_t green, uint8_t blue)
s_red = red;
s_green = green;
s_blue = blue;
ESP_ERROR_CHECK(led_strip_set_pixel(s_led_strip, 0, red * ratio, green * ratio, blue * ratio));
void light_driver_set_level(uint8_t level)
s_level = level;
void light_driver_set_power(bool power)
ESP_ERROR_CHECK(led_strip_set_pixel(s_led_strip, 0, s_red * power, s_green * power, s_blue * power));
void light_driver_init(bool power)
led_strip_config_t led_strip_conf = {
.max_leds = CONFIG_EXAMPLE_STRIP_LED_NUMBER,
.strip_gpio_num = CONFIG_EXAMPLE_STRIP_LED_GPIO,
led_strip_rmt_config_t rmt_conf = {
.resolution_hz = 10 * 1000 * 1000, // 10MHz
ESP_ERROR_CHECK(led_strip_new_rmt_device(&led_strip_conf, &rmt_conf, &s_led_strip));
light_driver_set_power(power);
Hi there, I haven't looked at this for a while.
Been picking it up again and following up on your code but I seem to be getting lots of compile errors and not a lot of success.
I have used the example esp-idf/examples/zigbee/light_sample/HA_on_off_light and replaced with your code from above.
Sorry, I'm late to the game here and foggy-headed after the dreaded Covid.
Any guidance or nudges are gratefully received.
Cheers
Dave
I am still having issue. Is your working fine?
Can you please share the complete code folder.
Are you using C7 or C8??
I was able to get the zigbee temperature sensor example to work with this code and this driver HubitatPublic/examples/drivers/environmentSensor.groovy at master · hubitat/HubitatPublic · GitHub
I am setup to use VSCode for esp32 and your code looks to be arduino version.
I will try your code tomorrow once I setup for that.
I got following response from esp32 team regarding their HA_on_off_light example
Regarding this issue, it appears to be triggered by a mismatched TC link key between
hubitat
and theon_off_light
example of the esp-zigbee-sdk. You can refer to the log below:ZBOSS: secur/apsme_secur.c:653 received link key identical to provisional link key - drop packet and fail tclk exchange
The default TC link key for the esp-zigbee-sdk example is
5A:69:67:42:65:65:41:6C:6C:69:61:6E:63:65:30:39
("ZigbeeAlliance09"). However, you can call the esp_zb_secur_TC_standard_preconfigure_key_set() function to configure the TC link key to match thehubitat
Do you know anything about how to get TC link key for Hubitiat? I did not find it in settings.
@JBrown Can you please attach arduino sketch as a file. The copy paste is causing lot of errors.
I don't know how I messed that up. Try this link.
Now it compiles and uploads fine. But now I am getting error
Guru Meditation Error: Core 0 panic'ed (Load access fault). Exception was unhandled.
I have not come across that error. Which ESP32 are you using, I'm using a ESP32-C6?
You may want to add this file from the example skitch. I complied with and without this file and saw no differance.
I'm using these settings for the Arduino IDE
Tools -> Zigbee mode: Zigbee ED (end device)
Tools -> Partition Scheme: Zigbee 4MB with spiffs
Tools -> Erase All Flash Before Sketch Upload : Enabled
Also I'm using Arduino Core Release v3.0.2 which came out about two weeks ago.
Sorry I could not be more help.
I did not read readme.
I followed the steps mentioned in readme and it worked fine.
Now hubitat finds zigbee device but fails to pair with it with following error
The device join failed and was not added to your network. Make sure the device is compatible before trying to pair the device again.
I have C7 and C8. And same issue with both....
any progress on this ?
Realize I'm late to the party here but excited to see if a c6 can work with hubitat. probably a stupid question, but how do you put the device in zigbee pairing mode?
If I remember correctly, after flashing the code to the C6 it automatically entered pairing mode.
@snell
I am working on this subject with an engineer from Espressif named Jan Procházka
After taking captures from the Zigbee network , he suggested disabling key exchange on the Zigbee library using the code:
"esp_zb_secur_link_key_exchange_required_set(false);"
with that workaround , the problem is solved and now I can use the esp32-c6 module with my Hubitat C8 hub and it is stable.
Assuming it was a C7 hub he suggested that the problem comes from lack of Zigbee 3.0 support. However, I was using a C8 for my latest tests, yet it did not work when key exchange was forced.
Now he wants me to ask on the Hubitat support if they have correctly implemented the exchange key (APS key)
I don't have direct access to Hubitat support. I believe support is ignoring me because they don't like my direct approach to the problems.
If anyone can ask this to Hubitat support, maybe we can understand and then maybe resolve the issues with esp32 support on Hubitat.
