Today I was noticed that many of my devices were not responding. Then I got a notification via a Rule I have that my Zigbee radio went offline. A quick search of the logs showed this
Device 2 seems to be implicated. It's my Office Desk Light, a very simple on/off lamp controlled by a Generic Zigbee Outlet (actually an Innr SP 222-2). I have several of these, all of which have been operating just fine for months.
A reboot of the HE brought the Zigbee radio back online, and everything seems to be back to normal (inclduing the Office Desk Light), but I'm a bit concerned as to what my cause this.
Any ideas what could be the cause, or where I could start looking?
those logs indicate that a job was scheduled (checkPresence) with a non hubitat driver, then the driver was changed to a hubitat driver which doesn't have a checkPresence method.
You can remove this scheduled job by temporarily replacing the current driver with the "Device" driver and clicking the deleteAllScheduledJobs command
I was out all morning but received a notification via a rule i have that zigbee had gone offline. When i got back home later i searched in the logs for zigbee and came up with the info shown in the screenshot in my first post.
A reboot fixed the issue and all now appears to be fine. I've removed the scheduled jobs as suggested by Mike above, and then put the driver back as "Generic Zigbee switch"
As I said, I am certain I did not change the driver - this was my first device in HE, the driver was chosen automatically when I added the device, and I've never touched it since in 7/8 months
Fingers crossed that's the last of it, but I still have no idea what happened
right, so one of those (no idea which one) is a match for the zigbee outlet that we are talking about, when this is the case the system will choose the user driver over the system driver when the device is joined...
Bottom line is the only way that job could have been scheduled was via a user driver since none of the inbuilt drivers use or have ever used or implemented a method named checkPresence.
I do have a couple of Salus SP600 smart plugs, but neither of them are in use at the moment (by which I mean they are in a cardboard box in my office, not plugged into power, and not utilised by any rules). The devices themselves are no longer defined to HE, so the drivers are not used. Anyway, just to be on the safe side, I have deleted the drivers from HE
The only Tuya device I have is a Smart Knob using the Tuya Scene Switch TS004F driver. This is defined to HE, but not used at the moment, so again to be on the safe side I have deleted the device and the associated driver.
