Zigbee radio goes offline briefly since 2.4.3.173
zigbee radio on C7 goes offline briefly roughly once every few days since update to 2.4.3.173. both times hub was shutdown and powered off for 15mins afterwards. This did not happen on 2.4.3.172 or earlier. Let me know if i can provide any additional info to assist w/ narrowing down this issue.
systemStart System startup with build: 2.4.3.173 2.4.3.173 1/06/2026 12:42:33.358 pm
manualShutdown shutdown called from 127.0.0.1 1/06/2026 12:11:15.991 pm
zigbeeStatus Zigbee radio is online online 1/06/2026 12:11:11.377 pm
zigbeeStatus Zigbee radio is offline offline 1/06/2026 12:11:04.126 pm
cloudBackup Cloud backup successful success 1/06/2026 1:28:09.097 am
cloudBackup Cloud backup successful success 1/05/2026 1:27:59.933 am
cloudBackup Cloud backup successful success 1/04/2026 1:28:13.611 am
systemStart System startup with build: 2.4.3.173 2.4.3.173 1/03/2026 12:07:54.220 pm
manualShutdown shutdown called from 127.0.0.1 1/03/2026 11:38:35.255 am
zigbeeStatus Zigbee radio is online online 1/03/2026 11:38:30.370 am
zigbeeStatus Zigbee radio is offline offline 1/03/2026 11:38:23.321 am
cloudBackup Cloud backup successful success 1/03/2026 1:28:09.394 am
systemStart System startup with build: 2.4.3.173 2.4.3.173 1/02/2026 1:22:32.692 pm
update Updated with build: 2.4.3.173 2.4.3.173 1/02/2026 1:14:47.665 pm
One more today:
zigbeeOn Zigbee radio is online zigbeeOn SYSTEM 1/09/2026 5:54:17.694 pm
zigbeeOff Zigbee radio is offline zigbeeOff SYSTEM 1/09/2026 5:54:12.104 pm
How busy is this C7?
It’s not that busy, the only time i get elevated hub alerts is right after a reboot. hubstats says cpu usage mostly stays under 30% but will peak up to 50% if i trend the data over 30days.
The only zigbee “recent” changes that i maid is that i changed my channel to 26 because it was the quietest and i removed the zigbee devices that didn’t support the channel… but it’s been ~a month since i made that change.
I’m gonna try 2.4.3.176 today just to see but from the release notes i dont see anything has been done to zigbee for a while.
I'm mostly not doing zigbee anymore, but you knew the 8 second zigbee radio reboot used to be a thing, right? I forget if it was ever solved, formally.
Well reading about the radio reboots did help put things into perspective. I did find a zigbee outlet that was reporting power metrics even though it was set not to. Hopefully the firmware update will fix that. Maybe it was a contributing factor :man_shrugging:t3:
Starting firmware update for AV Battery AC input, Third Reality, Inc from 1001305C to 10013065.
Unfortunately the HE hub is not very good at telling us what is wrong with it. Even if the aggregate metrics like CPU load look good there could still be enough going on to starve the radio. Last time this happened here on a C7 I had added a couple of mmWave sensors paired to another hub via hub mesh. Taking them off again got rid of the issue.
yeah agree, hubitstats is only set to poll cpu usage every 7mins… A LOT can happen on a cpu in 7mins.
On the zigbee side i am finding that my thirdreality zigbee outlets are having issues setting the Electrical Measurement cluster before the firmware update. Afterwards it does look like they are setting correctly.
IDK if this is the smoking gun, but i do have several of them and it is possible they could have spammed the zigbee radio all at once with power updates.
@bobbyD IDK if this is on your feature release schedule, but it would be nice to get updates/notified when new zigbee firmware is available. Release notes too would the the icing on the cake.
PM
debug
reporting configuration for Electrical Measurement (cluster 0x0B04) failed data:[8B, 00, 0B, 05]
dev:48852026-01-10 12:10:31.936 PM
debug
descMap:[raw:catchall: 0104 0B04 01 01 0040 00 4B66 00 00 0000 07 01 8B000B05, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4B66, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[8B, 00, 0B, 05]]
Been doing this on mine for as long as I can remember ..
I have never figured out why or how .. I just ignore it.
and as far as I can tell .. really has no impact on how the hub works.
I'm the same. Happens roughly every 3-4 days.
It's a C8 and been happening for at least a year as I moved 1 year ago, It was happening in my old home and it's happening in my new home which is smaller and has fewer devices installed.
Not a big issue as it comes back online around 8 seconds after going offline.
I've set up a WC piston which sends me a pushover message when it goes online/offline. At least I know it comes back OK.
With my C-8 this started happening enough that it was impacting use. Some days it happened only a couple of times. Other days it might be several time per hour. Nothing had changed and I could never pinpoint what was causing it. Staff looked at my hub and couldn't find anything. They sent me a new hub anyway (I have hub protect). It never happened on the new C-8. Zigbee was rock solid. And, again, nothing had changed except the hub hardware. I have a C-8 Pro now and it's never happened on this one either.
IDK if this will help anyone but, it’s been a week w/o zigbee radio reboots. I’m not sure why updating my thirdreality zigbee outlets firmware or resetting the Electrical Measurement cluster back to disabled brought stability back to the radios but it looks like it did.
Nothing really lead me to the devices other than knowing my environment and looking for anything that didn’t look correct in the logs… regardless of how trivial.
One theory is that Zigbee reboots happen when the hub fails to service the Zigbee network co-processor (NCP) on time, which causes the NCP to go into error state, requiring said reboot to resolve.
This situation can happen either because the NCP needs "too much attention" (e.g. bursts of Zigbee messages to process) or if the host platform (HE) is too busy with other things and starving it for attention (in my recent case, lots of events coming in through hub mesh).
It's a balance of factors and that's what seems to make it hard to diagnose one specific cause, sometimes.
