Zigbee Offline notification - It's lying!
Seem to be getting quite a lot of this recently..
Sometimes a reboot clears it. Sometimes not.
Browse: Chrome Version 70.0.3538.77 (Official Build) (32-bit)
Firmware: 1.1.7.120
Anyone else or is it just me?
Andy
I was seeing the same thing too. Reboot and it went away for me so far.
Never seen it. BUT.. now I've cursed it and so...
On the other hand, I only have 5 devices. 4 Iris motion sensors and a Peanut Plug.
I get it all the time. A reboot usually clears it...temporarily. I have learned to ignore it.
There currently is a known issue that if the zigbee radio goes offline the message persists even after the zigbee radio comes back online. This will be fixed in the next release.
Yes, I've had this too.
I had that message around two weeks ago. Reboot cleared it and I haven't seen it sense.
In addition to the above: they've said previously that when the hub is under load, the ZigBee network is the first to go. I'm not sure how taxed the hub is under normal use, but many webCoRE users notice high usage shortly after the hub boots...and sometimes forever afterwards. :slight_smile: (I assumed this disproportionatly affected hubs with webCORE installed, but I'm not sure how common it is across the board.)
