I cant get it back online.
Tried rebooting hub, removing zigbee stick. Turning hub off (via shutdown).
Thoughts?
Thoughts?
Contact support and also try disable and re-enable Zigbee in Zigbee info page.
Yep, tried enable, disable...
Just to be sure. Check to see if any Zigbee device is working and not just the false Zigbee offline message.
Yeah, nothing is working. I do have the message, but this time the message is correct.
I guess that's above my knowledge. Hope you will get it back soon.
Try a roll back?
Restore a backup dB?
There was a time I would have tried joking βitβs only zigbee, who needs itβ back when my zigbee inventory was zero. But now I have 4motion sensors and I can say iβm Sympathetic today
It seems to have come back up. I've no idea why.
Maybe multiple reboots (safe reboots) are required?
Probably was restoring a backup dB on its own, takes some time apparently
Was down for 5 hours, so probably not DB backup (but thanks for the help!).
Yikes, ok, that would be catastrophic
I am fairly sure my hub did this once. It is as acting super funny after a few reboots it settled out. I then started noticing code I had updated was outdated again. Thought I was going crazy. I came to the conclusion the hub eventually decided a backup was better than moving forward with whatever corruption was present.
If you added stuff, it would be missing them if the dB was from a day or more ago
