Ouch - I Just added a zigbee plug, and since then my Zigbee network is offline. ( I obviously remove the plug just in case)
I looked on the Forum - I tried a few things, like
I can see Zigbee starts, then goes offline.
Is there any log I can look at to troubleshoot the problem ?
Ouch, mind sharing what that plug was (make and model)? Also, please send me a private message. I would like to check your hub's engineering logs to see what happened. There isn't much you can do to troubleshoot this issue.
