Zigbee motorized zebra shades - not showing any commands
Hi dear community,
I bought some motorized zebra shades on alibaba and the vendor said these are smart and can be controlled with help of any hub which supports zigbee devices . I am able to add the device to the hub , but I don’t see any controls on it , not sure if I need to install any specific driver ,
Could some one help me
Here are the device details of this could help
Device Details
Create Time 1/24/2025, 11:33:37 PM
Last Update Time 1/25/2025, 11:23:01 AM
Last Activity At 1/25/2025, 11:22:36 AM
Controller Type ZGB
Device Data
Application 48
In Clusters 0000,0004,0005,EF00
Manufacturer _TZE200_9p5xmj5r
Model TS0601
Out Clusters 0019,000A
Software Build null
Try the ZemiSmart Zigbee Blind driver at HPM.
I just tried and it doesn’t seem to be working ..
Hi I bought zebra shades on alibaba which are motorized and I am trying to setup these with Hubitat hub . I was able to discover the blind on the hub , but I am not seeing any commands which works .
In tried asking the manufacturer and they just said to configure with any zigbee hub .
I posted it already in help group and some body said to use zemismart driver , even that didn’t help , could someone please help me .
Device Details
Last Update Time 2/5/2025, 6:26:08 AM
Last Activity At 2/5/2025, 6:26:18 AM
Controller Type ZGB
Device Data
Application 48
Model TS0601
Software Build null
Tuya Version 1.0.8
I see there was already a post for this, did you check?
To install the custom driver, use HPM or add the code to drivers code. Then on the device info page, you change the "Type", which is the driver, to use the custom driver. Then press configure on the commands page.
What exactly is not working?
@sureeshome I merged your duplicate posts, creating a duplicate for the same issue only creates confusion.
I have installed the Zemismart Zigbee driver via HPM and added the type as this on the device info page .
here is the picture of the device info
and below is the commands tab
when i clicked on configure , there were no errors in the log , But when i click on close so that it closes the blinds , it throws error
Just pasting the latest logs from the point i clicked on configure
dev:32025-02-05 09:30:00.355 AM
error
java.lang.ClassCastException: null (method endOfMovement)
dev:32025-02-05 09:29:57.878 AM
error
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'int'. Try 'java.lang.Integer' instead on line 860 (method close)
dev:32025-02-05 09:29:46.307 AM
info
ZebraLR7 ZebraLR7 configured : model=TS0601 manufacturer=_TZE200_9p5xmj5r
sorry for creating multiple posts , but i wasn't getting any response on the other post so thought i might have posted on the wrong section or something .
I will look at these errors tomorrow, probably the reason is because this is a new, unknown device and some initialization steps are missed. I suppose you have installed this custom driver after the motor was already paired as a generic type ‘Device’ ?
Have you tried clicking on the Preferences tab ‘Save’ button?
Also, if you open/close the motor from its remote, do the HE device attributes change?
Thank you for the screenshots.
I will look at these errors tomorrow, probably the reason is because this is a new, unknown device and some initialization steps are missed. I suppose you have installed this custom driver after the motor was already paired as a generic type ‘Device’ ? -- Yes i did it after motor was already paired as a generic device
Have you tried clicking on the Preferences tab ‘Save’ button? - Thank you !!!! I just did this step and tried again and magically its working , But there is an issue with remote given by the manufacturer after i paired this with hubitat, Usually on the remote when i press down arrow , the blinds roll down and when i press up arrow the blids roll up . Strangely after this hubitat pairing , that pattern reversed on the remote , what could be the problem ???
Also, if you open/close the motor from its remote, do the HE device attributes change? Yes attributes are chaging when i operate with the motor's remote
