I am getting the WiFi version as well as I use SmartLife and have the Tuya IoT running numerous plugs.
However trying to move towards Zigbee or Zwave. I have searched the web and community and tried various drivers, Whilst I can get connectivity and some info back none are giving any sort of Lux level.
Did you go into preferences and select TS0222? I would think that it would auto detected, since that is the default, but I would try selecting TS0222 specifically as Model Group.
You should also press initialize after a driver change (if by chance you didn't)... the driver may ask you to wake the device after initialize or preference update in the _info attribute.
This is a new device and its fingerprint is not in the driver code yet, I will add it in the next update. For now, manually confgure "TS0222_2" Model Group in the Preferences tab and click on the "Save and Close" button :
This is a battery-powered Zigbee device that requires pairing to your hub again (without deleting it) to ensure proper initialization during the pairing process. Your previous screenshot shows "rxCtr":0 in the State Variables - this is a counter of the received Zigbee messages, so nothing was ever received from the sensor. Pair it again, close to the hub.
