I don't thin I am getting lost. I was/am just wondering where the advantage of a new Mesh on a new hub is, when the devices are in different Mesh networks anyway
Tried it with the GU10 first:
dev:3162021-08-01 23:52:54.825 errorjava.lang.NullPointerException: Cannot get property 'requested' on null object on line 402 (method on)
[dev:316](http://192.168.50.92/logs#dev316)2021-08-01 23:52:54.781 [debug](http://192.168.50.92/device/edit/316)on()
[dev:316](http://192.168.50.92/logs#dev316)2021-08-01 23:52:39.317 [debug](http://192.168.50.92/device/edit/316)descMap:[raw:catchall: 0000 8022 00 00 0040 00 B367 00 00 0000 00 00 4788, profileId:0000, clusterId:8022, clusterInt:32802, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:B367, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[47, 88]]
[dev:316](http://192.168.50.92/logs#dev316)2021-08-01 23:52:38.923 [debug](http://192.168.50.92/device/edit/316)descMap:[raw:catchall: 0000 8022 00 00 0040 00 B367 00 00 0000 00 00 4688, profileId:0000, clusterId:8022, clusterInt:32802, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:B367, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[46, 88]]
[dev:316](http://192.168.50.92/logs#dev316)2021-08-01 23:52:38.506 [debug](http://192.168.50.92/device/edit/316)descMap:[raw:catchall: 0000 8022 00 00 0040 00 B367 00 00 0000 00 00 4588, profileId:0000, clusterId:8022, clusterInt:32802, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:B367, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[45, 88]]
[dev:316](http://192.168.50.92/logs#dev316)2021-08-01 23:52:38.416 [warn](http://192.168.50.92/device/edit/316)description logging is: true
[dev:316](http://192.168.50.92/logs#dev316)2021-08-01 23:52:38.412 [warn](http://192.168.50.92/device/edit/316)debug logging is: true
[dev:316](http://192.168.50.92/logs#dev316)2021-08-01 23:52:38.408 [info](http://192.168.50.92/device/edit/316)updated...
Another device (not rejoined):
dev:1962021-08-01 23:51:30.945 debugon()
[dev:196](http://192.168.50.92/logs#dev196)2021-08-01 23:51:23.187 [warn](http://192.168.50.92/device/edit/196)description logging is: true
[dev:196](http://192.168.50.92/logs#dev196)2021-08-01 23:51:23.184 [warn](http://192.168.50.92/device/edit/196)debug logging is: true
[dev:196](http://192.168.50.92/logs#dev196)2021-08-01 23:51:23.180 [info](http://192.168.50.92/device/edit/196)updated...
What make devices? As I said:
Philips Hue GU10
ikea Tradfri E27
Ostram Lightify RGBW Strip
Innr RGBW Lightstrip
Philips Hue Filament
