Zigbee, double log entries, periodically
2.3.1.142 C7
My "sensor" is (supposed) to send a message string every 5 minutes. Looking at the logs I find periodically I will receive double messages with nearly the same time stamp. Actually some have the identical timestamp.
When the double messages occur there are usually 3 to 5 bad messages then OK for some hours.
Have others seen this? Should I look to the hub or the sensor to try and track down the issue?
John
dev:36052022-04-28 08:41:26.991 pm errorjava.lang.ArrayIndexOutOfBoundsException: 1 on line 66 (method parse)
dev:36052022-04-28 08:41:26.985 pm info  Zigbee Msg#  04
dev:36052022-04-28 08:41:26.983 pm infoevent [:]
dev:36052022-04-28 08:41:26.981 pm info Raw Description  read attr - raw: F2890100140A0E00410104, dni: F289, endpoint: 01, cluster: 0014, size: 0A, attrId: 000E, encoding: 41, command: 0A, value: 0104
dev:36052022-04-28 08:41:26.981 pm info  Zigbee Msg#  01062314
dev:36052022-04-28 08:41:26.979 pm infoevent [:]
dev:36052022-04-28 08:41:26.977 pm info Raw Description  read attr - raw: F289010014100E00410401062314, dni: F289, endpoint: 01, cluster: 0014, size: 10, attrId: 000E, encoding: 41, command: 0A, value: 0401062314
dev:36052022-04-28 08:36:16.647 pm errorjava.lang.ArrayIndexOutOfBoundsException: 1 on line 66 (method parse)
dev:36052022-04-28 08:36:16.586 pm info  Zigbee Msg#  04
dev:36052022-04-28 08:36:16.586 pm info  Zigbee Msg#  01062314
dev:36052022-04-28 08:36:16.584 pm infoevent [:]
dev:36052022-04-28 08:36:16.581 pm info Raw Description  read attr - raw: F2890100140A0E00410104, dni: F289, endpoint: 01, cluster: 0014, size: 0A, attrId: 000E, encoding: 41, command: 0A, value: 0104
dev:36052022-04-28 08:36:16.581 pm info Raw Description  read attr - raw: F289010014100E00410401062314, dni: F289, endpoint: 01, cluster: 0014, size: 10, attrId: 000E, encoding: 41, command: 0A, value: 0401062314
dev:36052022-04-28 08:31:06.173 pm info  Zigbee Msg#  010623140404
dev:36052022-04-28 08:31:06.171 pm infoevent [:]
dev:36052022-04-28 08:31:06.169 pm info Raw Description  read attr - raw: F289010014140E004106010623140404, dni: F289, endpoint: 01, cluster: 0014, size: 14, attrId: 000E, encoding: 41, command: 0A, value: 06010623140404
dev:36052022-04-28 08:25:55.764 pm info  Zigbee Msg#  010623140404
dev:36052022-04-28 08:25:55.762 pm infoevent [:]
dev:36052022-04-28 08:25:55.759 pm info Raw Description  read attr - raw: F289010014140E004106010623140404, dni: F289, endpoint: 01, cluster: 0014, size: 14, attrId: 000E, encoding: 41, command: 0A, value: 06010623140404
dev:36052022-04-28 08:20:45.360 pm info  Zigbee Msg#  010623140404
dev:36052022-04-28 08:20:45.358 pm infoevent [:]
dev:36052022-04-28 08:20:45.356 pm info Raw Description  read attr - raw: F289010014140E004106010623140404, dni: F289, endpoint: 01, cluster: 0014, size: 14, attrId: 000E, encoding: 41, command: 0A, value: 06010623140404
