Zigbee devices not responding after 145 update
After the 145 &146 my C-7 zigbee devices arent responding.
Noticed it last night when I told Alexa to turn off living room light to no avail.
I thought Alexa was the problem, but then I decided to go directly to the device and try to control the zigbee plug and all the zigbee plugs like it. Then I checked zigbee motion sensors. Nothing worked.
Same issue here but with my z-wave device on the C7. Had to switch my devices over to my C8 and remove the mesh I was using. Hopefully, the next rev will fix
:crossed_fingers:
Or - hopefully someone has insight into a resolution.
2.3.5.145 and 146 came out almost 2 months ago. I suspect your problem is something unrelated to those releases.
I'd suggest you start by shutting down your hub completely (shutdown and then removing power for 30 seconds), and then bringing it back up.
I'm pretty sure 145 was the one that accidentally messed up ZigBee on my C5. 146 fixed it.
