I just discovered Hubitat and am looking to switch from Home Assistant. I have a few Zigbee devices connected to HA via a Sonoff Dongle. Would the dongle just plug into the Hubitat hub? Is there a USB port on the hub? I can't make out the connections shown in the photos.
Now I have HA in a Proxmox VM but it's been giving me problems for some time now so I'm looking for something a bit simpler.
No, you can only use the radios built in to the hub (ignoring some early models, but that particular coordinator is unlikely to work then, either). Migration would be a manual process.
I don't want to make it more complicated than it needs to be. I'll only have two, maybe three, devices so if I can just use the hub without the antenna I'd be better off.
