When the battery in a Zigbee device dies, should simply inserting a new battery cause the device to start working again? Or does the device need to be included again?
I have a Samsung water leak sensor and the battery died about two months ago. I installed a new battery, but is there anything else I need to do?
But if it doesn't automatically re-join, there's no issue with running "Device Discovery" again.
Launch the HE "Start Zigbee Pairing"
Put your device into pairing mode and HE will come up with:
"Found Previously Joined Device"
And maintain all your names, rules.. etc.
FYI- Hub might not tell you "Found Previously Joined Device " but it will usually still reactivate the device
Check the device's page to see last event, to see if it reconnected
