I have a few zwave minimotes. They work fine with my HE hub.
However, I want to replace them with zigbee remotes.
Does anyone have experience with the device here:
would it work with builtin drivers or any custom driver ?
Just added one yesterday. Works with built in driver. Held is not available and no battery reporting for some reason. Too early to tell on stability.
thanks for this feedback.
"held is not available" - does that mean , the device doesn't have held feature , or HE driver not working with held ?
The device has the feature but it's been removed at the driver level as it's useless. 5 seconds to trigger the event is far too long.
Depends on the power of the device. Sometimes 5 seconds is perfectly acceptable.
These work great for me.
Others disagree and even call them dangerous!
I don't know what would be dangerous about them but I've had a lot of problems getting those to stay working with the hub for more than a few hours.
I'm with @Terk, there's nothing dangerous about them! The issue with all things Aqara/Mijia is simple - they work well if they are directly connected to the hub. If they go through repeaters, then it is essential for all the routers to be Aqara/Mijia compatible. The good news is that most Zigbee 3.0 routers are. The bad news is that most ZHA1.2 routers are not.
