Originally, I was going to install a switch to automate this setup, but Zooz advised since it didn't have a neutral that a ZEN51 would work better in the light fixture.
Unfortunately, after getting and attempting to install I tried to get Zooz to help, but they didn't like the pictures I provided because of how the wires were wired in the back of the boxes, so they couldn't give any recommendations.
Below is a drawn of what I have . . .
I am hoping somebody has done this setup before.
When I installed the ZEN51 I could control the lights with Hubitat only when the light was left in the on position from the switch.
Where are the lights connected in your lower diagram?
At the same box with the Line In like this:
Or the lights can connect one three-way, with the Line in the box with the other 3-Way:
That is the weird part.
Looks like your figure one except not sure how the light is getting fed because it is behind drywall.
Switch 3 only has the end of the 3 wire run from Switch 1.
Switch 1 has Line and the 3 wire switch run.
Light 1 has the two wire run with Line power.
The wire from switch 1 and the wire from light 1 cannot be the same because it would be loop.
There must be a box or something that I haven’t found which is part of this equation.
