I have 5 of the Zen37 devices using the Advanced driver.
4 of the 5 are paired using Zwave security.
The one that is NOT paired with Zwave security shows up in the device graph and works great.
The 4 that are paired with Zwave device security do not show up in the device graph and don't work very well. I sometimes have to push the buttons 2-3 times to get Hubitat to register a response from them.
Should I just repair these without Zwave security?
Security has no bearing on if a device will show up there..
I see that this device supports Long Range.. If it is included as LR, it will not show in there, because it is not a mesh device.
OK, I see in the Zwave details page the yellow LR. It would be nice if this could also be added to the Device Info page of the device details.
So I'm guessing then that S2 security is the cause of my issue then?
S2 is inherent to LR (i.e. every LR-paired device is also S2), but S2 is also an available option for (compatible) devices paired mesh.
If you use SmartStart to pair an LR-capable device, SmartStart will pair it LR by default. If you want to pair that device mesh instead, you need to deliberately set that up during the SmartStart pairing process.
No.. The device is included as LR.. The device graph is a display of the mesh and LR nodes aren't part of the mesh, they talk directly to the hub.
LR is better in so many ways, I would not recommend re-including without..
