ZEN34 LED control
Hi everyone. I've combed through a number of threads that mention the ZEN34, but couldn't find a definitive answer to this question:
Can I set the LED color with Rule Machine such that when "on" the LED is steady green, and when "off" the LED is steady red, for example?
I looks like others may have done this, but perhaps only with a ZEN32 or other ZEN switch. I couldn't find the ability in Run Custom Actions with the driver I have, but I still remain hopeful. :smile:
Per the manual you can change the LED color of the upper and lower paddle independently using the parameters which is how it is done on the other Zooz devices you mentioned. Unfortunately since the ZEN34 is a battery powered device you would have to wake it up each time for the change to take place so its not going to work.
Ah. The fact that as a battery device it would need to get a wake-up makes sense, and didn’t think of that element.
I was adjusting parameters and setting the LED per the manual which is why it felt so within reach.
Thank you.
