ZEN31 not lighting LED RGB strip
I have it connected to my hub, but no matter what I select on the device page, nothing works. The status shows the strip is on, but no lights. What am I missing?
Has it worked before, or it was just setup? I assume your other Z-Wave devices are working fine?
I can think of a few possibilities:
  1. The device is defective. Are you able to confirm that it works? A volt meter might help with this.
  2. The light strip is defective. Can it be connected directly to a 12v (or 24v?) power source to confirm it works? Is the Zen31 providing the voltage that the light strip requires?
  3. The Z-Wave signal is not getting to the device. This could be because it is too far from the hub or a repeating device, or because it is in a location that is shielding it from the signal. It could also be caused by an issue with the Z-Wave mesh. Have you had mesh issues or ghosts?
  4. There is a problem with the driver. Try a different driver (ex.: community, generic RGBW bulb driver or the stock driver) to see if it makes a difference.
There are certainly other potential causes or things to try, but I would start with those.
New install. The light strip was connected to a controller with ir remote previously, which worked fine. The distance from the ZEN31 to Hubitat is probably 8 feet. Nothing can be too far away, as this is all in my motorhome. Other ZWave devices work fine. I haven't checked the voltage going to the light strip yet, will do tomorrow. I'm using the Zooz RGBW Dimmer (automatically selected.) I am also getting power information from the device, and it changes if the device is turned on (0.1) and off (0).
If you haven't already done so, I would recommend contacting Zooz support (assuming your purchased it new). They are generally pretty good about helping with things like this.
@agnes.zooz may have some suggestions as well.
I have four of these in use and have had no issues.
So the common wire of the light strip gets connected to the +12v line to the zen31 and then the RGBW terminals ground the individual color lines.
Just checking if you made that positive connection.
Yes, I have. Only difference in the diagram is I have no switches. And I have sent Zooz a support request. Thanks.
Might be interesting to test the switch part. I would try that myself, or try connecting two cables if I didn’t have a switch handy. Would confirm that voltage is flowing properly and eliminate the hub from the equation. Would also be interesting to see if the hub sees the status change, which I would expect it would since it sees power consumption changes.
Yeah. I don’t have the switch in any of my use cases either.
I checked the wiring from the ZEN to the lights. I was getting a reading of -13 volts. I said "WHAT!" as I quickly made sure I had the power going into the ZEN correct. I did. So, what is going on?
I had reused a pigtail that had come from an old RF RGB controller. I didn't pay much attention to the connections on the old controller, just assuming that Red is Red, Green is Green, and Blue is Blue, and the other White wire is +12. But Noooooooo. Blue is +12 and White is Blue. Luckily, I didn't do any damage. Thanks to all for the suggestions. It is now working perfectly, and much better than the previous remote.
Nice. Glad you got it working and thanks for the update.
