I am new to HE and am setting up a rule to set the dimmer level and turn on the light. I have a Zen27 switch and I can get it to turn on but the level is not taking. In the Actions page I have the light selected for the device and set the level to 75 with a 3 second fade. The light will turn on but not at 75%. Am I doing something wrong?
Welcome to Hubitat!!!
When setting a dimmer level you do not also need to turn on the light. Setting the level is enough, the light will also come on to that level. What is happening here is that the "ON" and "setLevel" commands are probably colliding with each other and one is being ignored. Try just using the "setLevel" command when the dimmer is off and see what happens. Good luck!!
I deleted the turn on action and the light turned on to the requested level with just the dimmer level action. Thanks for the help.
No problem and again, welcome to Hubitat!
