Definitely use Jeff's driver -- it's a godsend over any other driver out there.
Note this note (from link below) after you switch:
Must PRESS CONFIGURE BUTTON and check all your parameters after changing to this driver.
And when you set your desired parameters from the Details page, make sure you read each one's notes - Jeff tucks some important info in those when relevant.
