I just got a Zen16.
I plan to to wire the input from a bus bar that’s connected to my 12vDC lithium battery bank. I want to power an infrared 12v IR940 led light to add extra illumination for my security camera. The light is 12v 3amps. How should I wire it ? Do I simply wire the pos and neg wire to the #3 relay and wire the battery directly to the DC input ?
Wire pos/neg from the battery to the DC input of the ZEN16
The relay is just that, a relay. It just opens and closes a circuit.
For the LED, wire the negative directly to the LED, wire the positive to one terminal on any relay, then wire from the other terminal on the same relay to the pos on the LED.
When you switch the relay on and off you break the circuit, thus turning the LED on and off.
Ohhhh I see
Thanks that'll work great!
