Zen Thermostat Staying in Heating Mode
Hello All,
For some reason my Zen thermostat is staying in thermostatOperatingState : heating mode even when not blowing heat. Any ideas?
Two ideas:
  1. Take the thermostat off the wall, and if you're using batteries instead of (or in addition to) a C wire, remove them for a few seconds to power cycle the thermostat.
  2. After you've done that and it's back on and online, or if you just want to try this first: hit the "Configure" button on the device page. Maybe even try it twice for good measure.
I assume you're using the dedicated Zen Thermostat driver; if not, I'd see if that helps.
I've had a few minor quibbles with this thermostat, which I just replaced, in the past (I congratulate you on being able to achieve the elusive whole-degree setpoint ending in ".0"), but I don't think I ever saw this particular problem. :slight_smile:
Thank you sir :slight_smile:
