I just got a Zen thermostat. It looks like the temp is reading a couple of degrees high. Under the INFO section it shows the config and two numbers. For me it's 11B, 2.8, and 2.1. Does anyone know what the numbers are? Can they be changed?
If the temp is reading a bit high there should be an off-set setting on both the thermostat and the hubitat driver.
