Seems like a good use of AI to me. I just asked free DeepSeek to make a driver for the Zen Thermostat.
I don't have one, so I can't test it. Below is what it produced. Generally, AI does not get it right the first time. I've found I just try the code, and paste any errors from the debug logs right back into the session, and it figures out why those errors were produced. Once you have the code working, you can just paste the code back into DeepSeek and ask to to fix other things you notice are not working right, like your post here. Use any AI, but DeepSeek seems to do a good job with Hubitat code for me.
Zen Thermostat
* Zen Within Zigbee Thermostat (Zen‑01‑W) Driver for Hubitat Elevation
* Automatically detects supported thermostat and fan modes.
* Version: 1.2.0
* Date: 2026-04-13
* Changes:
* - Removed user preferences for supported modes
* - Added automatic detection of supported modes by reading Control Sequence
* of Operation (0x001B) and Fan Control Sequence (0x000B) from the thermostat cluster
* - Publishes supportedThermostatModes and supportedThermostatFanModes events
* based on device capabilities
import hubitat.zigbee.zcl.DataType
import hubitat.zigbee.clusters.Cluster
import hubitat.device.HubAction
metadata {
definition (name: "Zen Zigbee Thermostat", namespace: "yournamespace", author: "Your Name", importUrl: "https://raw.githubusercontent.com/.../zen-thermostat.groovy") {
capability "Thermostat"
capability "TemperatureMeasurement"
capability "Battery"
capability "Refresh"
capability "Configuration"
capability "Sensor"
command "setHeatingSetpoint", [[name:"Heating Setpoint", type:"NUMBER", description:"Heating setpoint in °C/°F", range:"10..30"]]
command "setCoolingSetpoint", [[name:"Cooling Setpoint", type:"NUMBER", description:"Cooling setpoint in °C/°F", range:"10..31"]]
command "setThermostatMode", [[name:"Mode", type:"ENUM", description:"Thermostat mode", constraints:["off","auto","heat","cool","emergency heating"]]]
command "setThermostatFanMode", [[name:"Fan Mode", type:"ENUM", description:"Fan mode", constraints:["auto","on"]]]
command "setTemperatureCalibration", [[name:"Calibration", type:"NUMBER", description:"Temperature calibration offset in °C/°F", range:"-2.5..2.5", step:"0.1"]]
command "refresh"
command "configure"
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0201,0202,0402", outClusters: "0019", manufacturer: "Zen", model: "Zen-01", deviceJoinName: "Zen Zigbee Thermostat"
preferences {
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
input name: "tempUnitPref", type: "enum", title: "Temperature Unit", options: ["C":"Celsius", "F":"Fahrenheit"], defaultValue: "C"
input name: "tempCalibration", type: "decimal", title: "Temperature Calibration Offset", description: "Adjust the reported temperature (±2.5°C/±4.5°F)", range: "-2.5..2.5", defaultValue: 0.0
input name: "heatingSetpointMin", type: "decimal", title: "Minimum Heating Setpoint", defaultValue: 10.0, range: "5..30"
input name: "heatingSetpointMax", type: "decimal", title: "Maximum Heating Setpoint", defaultValue: 30.0, range: "5..30"
input name: "coolingSetpointMin", type: "decimal", title: "Minimum Cooling Setpoint", defaultValue: 10.0, range: "5..31"
input name: "coolingSetpointMax", type: "decimal", title: "Maximum Cooling Setpoint", defaultValue: 31.0, range: "5..31"
input name: "tempReportInterval", type: "number", title: "Temperature Report Interval (seconds)", description: "How often the device reports temperature", defaultValue: 300, range: "30..86400"
input name: "tempMinReportInterval", type: "number", title: "Minimum Temperature Report Interval (seconds)", description: "Minimum time between reports", defaultValue: 30, range: "5..3600"
def installed() {
logDebug "installed()"
refresh()
configure()
def updated() {
logDebug "updated()"
if (logEnable) runIn(1800, "logsOff")
configure()
refresh()
def logsOff() {
log.warn "Debug logging disabled"
device.updateSetting("logEnable", [value: "false", type: "bool"])
private logDebug(msg) {
if (logEnable) log.debug msg
private logInfo(msg) {
if (txtEnable) log.info msg
private def sendZigbeeCommands(commands) {
if (commands) {
if (commands instanceof List) {
sendHubCommand(commands)
} else {
sendHubCommand([commands])
// Publish the lists of supported modes to the Thermostat capability
private void updateSupportedModes() {
def modes = state.supportedThermostatModes ?: ["off","auto","heat","cool"]
def fanModes = state.supportedThermostatFanModes ?: ["auto","on"]
sendEvent(name: "supportedThermostatModes", value: modes, displayed: false)
sendEvent(name: "supportedThermostatFanModes", value: fanModes, displayed: false)
logDebug "Detected supported thermostat modes: ${modes}"
logDebug "Detected supported fan modes: ${fanModes}"
// Map Control Sequence of Operation (0x001B) to thermostat mode list
private List<String> mapControlSequenceToModes(int ctrlSeq) {
// Values from Zigbee Cluster Library specification
switch (ctrlSeq) {
case 0x00: // Cooling only
return ["off", "cool"]
case 0x01: // Cooling with reheat
return ["off", "cool", "emergency heating"] // reheat can be considered emergency heat
case 0x02: // Heating only
return ["off", "heat"]
case 0x03: // Heating with reheat
return ["off", "heat", "emergency heating"]
case 0x04: // Cooling and heating
return ["off", "cool", "heat", "auto"]
case 0x05: // Cooling and heating with reheat
return ["off", "cool", "heat", "auto", "emergency heating"]
default:
logDebug "Unknown Control Sequence value: ${ctrlSeq}, using default full set"
return ["off", "auto", "heat", "cool"]
// Map Fan Control Sequence (0x000B) to fan mode list
private List<String> mapFanSequenceToFanModes(int fanSeq) {
// Values from ZCL spec:
// 0x00 = No fan control
// 0x01 = Multi-speed fan control (auto/on)
// 0x02 = Single-speed fan control (on only? Usually auto/on as well)
// For simplicity, we assume if fanSeq != 0x00, then both auto and on are supported.
if (fanSeq == 0x00) {
return [] // no fan control
} else {
return ["auto", "on"]
if (description?.startsWith("catchall:")) {
logDebug "Catchall: ${description}"
return
Map descMap = zigbee.parseDescriptionAsMap(description)
logDebug "Parsed: ${descMap}"
if (!descMap) return
if (descMap.clusterId == "0201") {
handleThermostatCluster(descMap)
} else if (descMap.clusterId == "0402") {
handleTemperatureMeasurement(descMap)
} else if (descMap.clusterId == "0001") {
handlePowerConfiguration(descMap)
private void handleThermostatCluster(Map descMap) {
// Handle attribute 0x001B: Control Sequence of Operation
if (descMap.attrId == "001B") {
int ctrlSeq = zigbee.convertHexToInt(descMap.value)
state.supportedThermostatModes = mapControlSequenceToModes(ctrlSeq)
return
// Handle attribute 0x000B: Fan Control Sequence
if (descMap.attrId == "000B") {
int fanSeq = zigbee.convertHexToInt(descMap.value)
state.supportedThermostatFanModes = mapFanSequenceToFanModes(fanSeq)
return
// Handle other thermostat attributes (heating setpoint, cooling setpoint, etc.)
if (descMap.attrId == "0000") {
def temp = zigbee.convertHexToInt(descMap.value) / 100.0
if (tempUnitPref == "F") temp = (temp * 9/5) + 32
sendEvent(name: "heatingSetpoint", value: temp, unit: getTemperatureScale(), descriptionText: "Heating setpoint is ${temp}${getTemperatureScale()}", displayed: true)
else if (descMap.attrId == "0011") {
sendEvent(name: "coolingSetpoint", value: temp, unit: getTemperatureScale(), descriptionText: "Cooling setpoint is ${temp}${getTemperatureScale()}", displayed: true)
else if (descMap.attrId == "0001") {
def calibratedTemp = temp + (tempCalibration as Double)
sendEvent(name: "temperature", value: calibratedTemp, unit: getTemperatureScale(), descriptionText: "Temperature is ${calibratedTemp}${getTemperatureScale()}", displayed: true)
else if (descMap.attrId == "001C") {
def mode = descMap.value
// Optional validation against supported modes, but still send event
sendEvent(name: "thermostatMode", value: mode, descriptionText: "Thermostat mode is ${mode}", displayed: true)
else if (descMap.attrId == "001D") {
def stateVal = descMap.value
def operatingState = "idle"
if (stateVal == "01") operatingState = "heat"
else if (stateVal == "02") operatingState = "cool"
sendEvent(name: "thermostatOperatingState", value: operatingState, descriptionText: "Operating state is ${operatingState}", displayed: true)
else if (descMap.attrId == "000A") {
def fanMode = descMap.value == "01" ? "on" : "auto"
sendEvent(name: "thermostatFanMode", value: fanMode, descriptionText: "Fan mode is ${fanMode}", displayed: true)
private void handleTemperatureMeasurement(Map descMap) {
private void handlePowerConfiguration(Map descMap) {
if (descMap.attrId == "0020") {
def voltage = zigbee.convertHexToInt(descMap.value)
def battery = voltage >= 3000 ? 100 : Math.round((voltage - 2400) / 600 * 100)
battery = Math.max(0, Math.min(100, battery))
sendEvent(name: "battery", value: battery, unit: "%", descriptionText: "Battery is ${battery}%", displayed: true)
def setHeatingSetpoint(temp) {
logDebug "setHeatingSetpoint(${temp})"
def minTemp = (heatingSetpointMin ?: 10.0) as Double
def maxTemp = (heatingSetpointMax ?: 30.0) as Double
temp = Math.max(minTemp, Math.min(maxTemp, temp as Double))
if (tempUnitPref == "F") temp = (temp - 32) * 5/9
def tempInt = Math.round(temp * 100)
sendZigbeeCommands(zigbee.writeAttribute(0x0201, 0x0011, 0x29, tempInt))
runIn(2, "refresh")
def setCoolingSetpoint(temp) {
logDebug "setCoolingSetpoint(${temp})"
def minTemp = (coolingSetpointMin ?: 10.0) as Double
def maxTemp = (coolingSetpointMax ?: 31.0) as Double
sendZigbeeCommands(zigbee.writeAttribute(0x0201, 0x0012, 0x29, tempInt))
runIn(2, "refresh")
def setThermostatMode(mode) {
logDebug "setThermostatMode(${mode})"
def modeValue
switch (mode) {
case "off":
modeValue = 0x00
break
case "auto":
modeValue = 0x04
break
case "heat":
modeValue = 0x01
break
case "cool":
modeValue = 0x03
break
case "emergency heating":
modeValue = 0x05
break
default:
logDebug "Unknown mode: ${mode}"
return
sendZigbeeCommands(zigbee.writeAttribute(0x0201, 0x001C, 0x30, modeValue))
runIn(2, "refresh")
def setThermostatFanMode(fanMode) {
logDebug "setThermostatFanMode(${fanMode})"
def fanModeValue = fanMode == "on" ? 0x01 : 0x00
sendZigbeeCommands(zigbee.writeAttribute(0x0201, 0x000A, 0x30, fanModeValue))
runIn(2, "refresh")
def setTemperatureCalibration(offset) {
logDebug "setTemperatureCalibration(${offset})"
device.updateSetting("tempCalibration", [value: offset, type: "decimal"])
sendEvent(name: "temperatureCalibration", value: offset, descriptionText: "Temperature calibration set to ${offset}${getTemperatureScale()}", displayed: true)
refresh()
def refresh() {
logDebug "refresh()"
List<HubAction> refreshCmds = []
refreshCmds += zigbee.readAttribute(0x0201, 0x0000) // Local temperature
refreshCmds += zigbee.readAttribute(0x0201, 0x0011) // Heating setpoint
refreshCmds += zigbee.readAttribute(0x0201, 0x0012) // Cooling setpoint
refreshCmds += zigbee.readAttribute(0x0201, 0x001C) // System mode
refreshCmds += zigbee.readAttribute(0x0201, 0x001D) // Running state
refreshCmds += zigbee.readAttribute(0x0201, 0x000A) // Fan mode
refreshCmds += zigbee.readAttribute(0x0402, 0x0000) // Temperature measurement
refreshCmds += zigbee.readAttribute(0x0001, 0x0020) // Battery voltage
// Also re-read the capability attributes in case they change
refreshCmds += zigbee.readAttribute(0x0201, 0x001B) // Control Sequence of Operation
refreshCmds += zigbee.readAttribute(0x0201, 0x000B) // Fan Control Sequence
sendZigbeeCommands(refreshCmds)
def configure() {
logDebug "configure()"
List<HubAction> configCmds = []
// Configure reporting for temperature, battery
configCmds += zigbee.configureReporting(0x0201, 0x0000, 0x29, tempMinReportInterval ?: 30, tempReportInterval ?: 300, 100)
configCmds += zigbee.configureReporting(0x0402, 0x0000, 0x29, tempMinReportInterval ?: 30, tempReportInterval ?: 300, 100)
configCmds += zigbee.configureReporting(0x0001, 0x0020, 0x20, 300, 3600, 100)
// Read capability attributes to determine supported modes
configCmds += zigbee.readAttribute(0x0201, 0x001B) // Control Sequence of Operation
configCmds += zigbee.readAttribute(0x0201, 0x000B) // Fan Control Sequence
sendZigbeeCommands(configCmds)
// If the device does not respond within a reasonable time, use default values
runIn(10, "fallbackSupportedModes")
def fallbackSupportedModes() {
if (!state.supportedThermostatModes) {
logDebug "No response from device for control sequence, using default modes"
state.supportedThermostatModes = ["off","auto","heat","cool"]
state.supportedThermostatFanModes = ["auto","on"]
