Could you re-post the code please? It returns a 404 error?
I have changed the driver a bit to support 2-gang and 3-gang switches. And the driver file was renamed.
Amazing!
I'm using for Zemismart 1 gang and 2 gang switches the driver from this topic:
And it works like a charm.
@muxa, Great job creating the driver and keeping it up-to-date. I just bought a Zemismart 3-gang switch and tried the Generic Zigbee Multi-Endpoint, which seems to work well and shows 3 child devices on the device list. Does your driver provide additional capabilities, or did HE just add your driver to standard drivers?
We never do that, the inbuilt driver was written from scratch...
Can anyone tell me if the zemismart zigbee 3 light switch maintains power to the lights when switched off? I am wanting to use them with smart bulbs so that I can still dim the bulbs. Thanks
Thank you so much, this has just solved my problem with MoesGo 2 gang Zigbee switches. Your settings worked great, no edits needed.
what settings? i have an issue where it only manages to use one gang and not both
I want to confirm the built-in Generic ZigBee Multi Endpoint Switch driver worked for me. Using it a Zemismart 2 gang KS-811 wall switch. Hubitat can control the 2 switched individually, or as one.
That's the first device I have with children, and it's slick.
Hi, I bought a 3 gang zigbee switch. The driver doesn't work for me. When I press the child switches all the lights are understood as if I touched the parent device, everything turns on/off.
I don't know if it's possible to get some help or know where to go since I never use this language or protocol
Thanks in advance
Is your 3-gang switch the zemismart brand? I just installed my 3-gang yesterday using the Generic ZigBee Multi Endpoint Switch driver and it is working perfectly.
Temporary switch to the inbuilt driver named ‘Device’, Press the ‘Get Info’ button, and please copy/paste here the fingerprint info line that should appear on the Logs page,
All,
An updated version of Muxa's "Zemismart ZigBee Wall Switch Multi-Gang" driver can be found at :
There are a lot of new 1/2/3/4 Gang Zemismart (Tuya) switches that are now supported by this driver.
As a general rule, always check first if HE inbuilt Generic ZigBee Multi-Endpoint Switch driver works for your Zemismart/Moes/Avatto/Any-Tuya-White-Label multigang switch. Most of the Tuya white-label manufactured switches should work fine with the stock driver.
Muxa's driver currently supports Tuya models TS0001 and TS0011 single gang switches; TS0002 and TS0012 2-gang switches, TS0003 and TS0013 3-gang switches and TS0004 4-gang light switches.
Revisions history
- Ver. 0.0.1 2019-08-21 Muxa - first version
- Ver. 0.1.0 2020-02-05 Muxa - Driver name "Zemismart ZigBee Wall Switch Multi-Gang"
- Ver. 0.2.1 2022-02-26 kkossev - TuyaBlackMagic for TS0003 _TZ3000_vjhcenzo
- Ver. 0.2.2 2022-02-27 kkossev - (development branch) 10:03 AM : TS0004 4-button, logEnable, txtEnable, ping(), intercept cluster: E000 attrId: D001 and D002 exceptions;
- Ver. 0.2.3 2022-03-04 kkossev - Power outage options
- Ver. 0.2.4 2022-04-16 kkossev - _TZ3000_w58g68s3 Yagusmart 3 gang zigbee switch fingerprint
- Ver. 0.2.5 2022-05-28 kkossev - _TYZB01_Lrjzz1UV Zemismart 3 gang zigbee switch fingerprint; added TS0011 TS0012 TS0013 models and fingerprints; more TS002, TS003, TS004 manufacturers
- Ver. 0.2.6 2022-06-03 kkossev - powerOnState and Debug logs improvements; importUrl; singleThreaded
- Ver. 0.2.7 2022-06-06 kkossev - command '0B' (command response) bug fix; added Tuya Zugbee mini switch TMZ02L (_TZ3000_txpirhfq); bug fix for TS0011 single-gang switches.
- Ver. 0.2.8 2022-07-13 kkossev - added _TZ3000_18ejxno0 and _TZ3000_qewo8dlz fingerprints; added TS0001 wall switches fingerprints; added TS011F 2-gang wall outlets; added switchType configuration
- Ver. 0.2.9 2022-09-29 kkossev - added _TZ3000_hhiodade (ZTS-EU_1gang); added TS0001 _TZ3000_oex7egmt _TZ3000_b9vanmes _TZ3000_zmy4lslw
- Ver. 0.2.10 2022-10-08 - _TZ3000_hhiodade fingerprint correction
- Ver. 0.2.11 2022-11-07 - added _TZ3000_tqlv4ug4
- Ver. 0.2.12 2022-11-11 - added _TZ3000_cfnprab5 (TS011F) Xenon 4-gang + 2 USB extension; _TYZB01_vkwryfdr (TS0115) UseeLink; _TZ3000_udtmrasg (TS0003)
- Ver. 0.2.13 2022-11-12 - tuyaBlackMagic() for Xenon similar to Tuya Metering Plug; _TZ3000_cfnprab5 fingerprint correction; added SiHAS and NodOn switches
- Ver. 0.2.14 2022-11-23 - added 'ledMOode' command; fingerprints critical bug fix.
- Ver. 0.2.15 2022-11-23 - added added _TZ3000_zmy1waw6
- Ver. 0.3.0 2023-01-07 - noBindingButPolling() for _TZ3000_fvh3pjaz _TZ3000_9hpxg80k _TZ3000_wyhuocal
- Ver. 0.3.1 2023-01-16 - restored TS0003 _TZ3000_vjhcenzo fingerprint; added _TZ3000_iwhuhzdo
- Ver. 0.4.0 2023-01-22 - parsing multiple attributes;
- Ver. 0.4.1 2023-02-10 - IntelliJ lint; added _TZ3000_18ejxno0 third fingerprint;
- Ver. 0.5.0 2023-03-13 - removed the Initialize capability and replaced it with a custom command
- Ver. 0.5.1 2023-04-15 kkossev - bugfix: initialize() was not called when a new device is paired; added _TZ3000_pfc7i3kt; added TS011F _TZ3000_18ejxno0 (2 gangs); _TZ3000_zmy1waw6 bug fix; added TS011F _TZ3000_yf8iuzil (2 gangs)
- Ver. 0.5.2 2023-06-10 - added TS0002 _TZ3000_5gey1ohx; unschedule all remaining jobs from previous drivers on initialize(); added _TZ3000_zigisuyh
- Ver. 0.5.3 2023-10-19 - added TS0001 _TZ3000_agpdnnyd @Sekenenz; added TS011F _TZ3000_iy2c3n6p @TomG
- Ver. 0.5.4 2023-10-29 - added TS0002 _TZ3000_qcgw8qfa
- Ver. 0.6.0 2024-01-14 - Groovy lint; TS0004 _TZ3000_a37eix1s fingerprint correction @Rafael;
- Ver. 0.6.1 2024-01-29 - added TS011F _TZ3000_pmz6mjyu @g.machado
- Ver. 0.7.0 2024-02-29 - (dev. branch) more Groovy lint; E000_D003 exception processing; ignored duplicated on/off events for the parent device; added ping() and rtt measurement;
The latest development branch driver version, which contains the last added new devices fingerprints and/or bugfixes/improvements can be manually downloaded from this link:
https://raw.githubusercontent.com/kkossev/hubitat-muxa-fork/development/drivers/zemismart-zigbee-multigang-switch.groovy
An archive of the previous driver versions can be found here.
Manufacturer: _TZ3000_w58g68s3
Product Name:
Model Number: TS0003
deviceTypeId: 914
manufacturer : _TZ3000_w58g68s3
idAsInt : 1
inClusters : 0003,0004,0005,0006,E000,E001,0000
endpointId : 01
profileId : 0104
application : 52
outClusters : 0019,000A
initialized : true
model : TS0003
stage : 4
manufacturer :
idAsInt : 2
inClusters : 0004,0005,0006,E001
endpointId : 02
profileId : 0104
application :
outClusters :
initialized : true
model :
stage : 4
manufacturer :
idAsInt : 3
endpointId : 03
profileId : 0104
application :
outClusters :
initialized : true
model :
stage : 4
manufacturer :
idAsInt : 242
inClusters :
endpointId : F2
profileId : A1E0
application :
outClusters : 0021
initialized : true
model :
stage : 4
@Hector thank you for the detailed device pairing information!
Is the latest driver version working OK with your 3-gang switch?
Including the powerOnState configuration?
I have to try this latest driver. I did a test this morning before going to work but I couldn't get all three lights to appear, only the parent. I have to retry again.
I have seen the new functionality, but did not have time to try.
I will try later and comment again.
Thanks in advance
Hey guys little help please just got a Tuya zigbee Model SML-03Z-L module Zigbee ID: "TS0013"; "_TZ3000_jl7qyupf"
All installed switches working manually perfect also found on hubitat but none of the switches are working through hubitat with this driver and generic zigbee multi endpoint.
Help
@ADDs Is your device is a 3 gang switch?
This driver has a fingerprint for the 2 gang version, if you confirm I will add your 3 gang switch in the driver.
What happens when you press the Initialize button? Do you have 3 child devices created?
Please make sure the Debug option is turned on, then press the on/off buttons on n the device web page and if it doesn’t work, copy and paste the debug logs.
