ZAC36 Activating Itself
I have a Zooz ZAC36 zone valve installed for about 6 months now in a secondary home. I have it tied to a ZEN32 button controller by the main entrance to turn the water on/off when we get into the house.
When I got here yesterday and hit the button, the valve opened and the water went on. 9 minutes later it went off. I turned it back on and it continued to go off. Then back on. then off, etc.
Was setup using the community driver by JTP10181 v1.0.6, so I switched it to the native hubitat one seeing if that would make a difference. It didn't. Switched back to community driver this morning, but it keeps activating itself either on or off.
Seems like the logs are telling me that it's from the physical button being pushed, which could mean I have a bad unit?
Table below (I have a screenshot but can't post it to forums)
Name Value Description Type Produced by Triggered Apps Date/Time H I J
temperature 54.9 temperature set to 54.9 F Water Main 12/06/2025 11:52:24.835 am
valve open valve set to open digital Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 11:40:50.192 am
valve open valve set to open binary Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 11:40:50.071 am
switch on switch set to on binary Water Main Entry Button Controller - B3 - Water Main Status (allHandler) 12/06/2025 11:40:50.052 am
valve working valve set to working binary Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 11:40:37.394 am
command-open Command called: open() command House Functions 12/06/2025 11:40:37.055 am
temperature 54.0 temperature set to 54.0 F Water Main 12/06/2025 11:36:39.678 am
valve closed valve set to closed physical Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 11:21:51.907 am
valve closed valve set to closed binary Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 11:21:51.828 am
switch off switch set to off binary Water Main 12/06/2025 11:21:51.809 am
temperature 54.9 temperature set to 54.9 F Water Main 12/06/2025 11:20:54.361 am
temperature 54.0 temperature set to 54.0 F Water Main 12/06/2025 11:05:09.175 am
temperature 54.9 temperature set to 54.9 F Water Main 12/06/2025 10:49:23.870 am
valve open valve set to open physical Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 10:40:43.864 am
valve open valve set to open binary Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 10:40:43.641 am
switch on switch set to on binary Water Main Entry Button Controller - B3 - Water Main Status (allHandler) 12/06/2025 10:40:43.611 am
valve closed valve set to closed physical Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 9:55:41.530 am
valve closed valve set to closed binary Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 9:55:41.384 am
switch off switch set to off binary Water Main Entry Button Controller - B3 - Water Main Status (allHandler) 12/06/2025 9:55:41.365 am
valve open valve set to open digital Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 8:21:56.940 am
valve open valve set to open binary Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 8:21:56.811 am
switch on switch set to on binary Water Main Entry Button Controller - B3 - Water Main Status (allHandler) 12/06/2025 8:21:56.799 am
valve working valve set to working binary Water Main Custom Mirror:Water Main (sourceHandler) 12/06/2025 8:21:44.184 am
