Z-wave unresponsive?
I upgraded from C7 to C8 pro and now every few weeks I'd wake up to see that my 3am backup failed due to an unresponsive Z-wave
Rebooting would solve the problem.
Now I'm hoping to create an automation rule that if backup fails for this reason, trigger a reboot. How can I trigger a rule with this signal? :slight_smile:
Are you just rebooting? Shutdown and power removed for a few mins should do a better job on the zwave radio. Also hub fw version, zwave z-ip or zwavejs could be beneficial. the links below have more details.
C8 Pro Zwave Radio Unresponsive - #3 by rob9.
I don't recommend doing that, instead, I'd provide more details such as platform version and Z-Wave protocol. If you are not up to date and running Z-Wave JS, I would do that 1st.
Thank you BobbyD! I tried your suggestion and now running Z-Wave JS and it worked for a month or so and ran into the same problem. I wonder if you have any other suggestions I can try? Thank you!
